Question about Omron Model HEM 432C Manual Inflation Blood Pressure Monitor
What does it mean when you get a reading then 3 consecutive readings say EE
  • 5,481 Answers
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Posted on Sep 09, 2010
What does EE mean under the Systolic reading on a Marshall tm91 Oscillometric ??
This is an error state.. Probably too noisy kortoff sounds to register if too high for cheap home units.. Probably need to test with cuff and stethoscope.
Sep 20, 2014 | Health & Beauty
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
E
E
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron
https://omronhealthcare.com.au/pdf/SEM-1_Instruction_manual.pdfThe SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
My Ironman has EE:EE on the display, The Chrono reads "Memory Full". Does this mean I need a new battery?
I doubt if your watch is faulty. If you read your instructions I would expect you to be able to empty the memory.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 16, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
Reading says EE 2 what does this mean
Hi Sandra, EE 2 means that the heater did not ignite. There could be several causes. First let me ask, did the heater make a ticking or thumping sound before you got the EE 2? If so that means the fuel isn't getting to the fuel sump. It could be caused by an air bubble in the fuel line, a clogged filter at the tank (if you use an outside tank), or a clogged fuel strainer in the fuel sump. EE 2 could also be caused by a bad igniter. Did the heater light at all? If it did then the igniter is good. If it didn't the easiest way I have found to check the igniter is to use a clamp on ammeter or use a multimeter to check the resistance of the igniter. Another cause is a dirty flame rod. If the heater lit then went out I would suspect this. It can be cleaned with some steelwool or fine sandpaper. Let me know what you find or if you need more info.
Oct 04, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
E"E" reading
From what i have seen EE means overload warning, I looked on the website your scale has a lifetime warrenty on it i would recomend calling customer service @ For Customer Service: 800-289-0944 before messing around with anything.
Apr 15, 2009 | Taylor 5743 BIA Body Fat Scale
Lenses
It likely means that the aperture ring on the larger lens is not set to the minimum f-stop number, i.e. f22 f32, usually orange.
Jun 28, 2008 | Nikon D70s Digital Camera
Omron Model HEM 432C Manual Inflation Blood Pressure Monitor Logo
709 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
