Question about Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive
My PDHD1000 hard drive starts but does not boot up and connect to my computer like it used to.
    President:
  • 1,768 Answers
You have a usb controller board that is malfunctioning and it or the case for the usb hard drive needs to be replaced.
the power regulator that is built into the usb controller is not working therefore the usb logic circuit cannot transmit the signal to the PC viia the USB port and will not recognize the device. You can order or purchase a new case that will accommodate the hard drive from your local computer store.
Posted on Sep 09, 2010
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
IBM thinkcenter says no os after installing DVD writer
Did you install a SATA or an PATA (IDE) drive?
First check that the data cables are connected to both the hard drive and the motherboard. (I know that I've frequently had the cables come loose from the motherboard on my ThinkCentre 8433 when I work in the case.) Also check that the power cables are firmly connected.
Next make sure that you have no disc in the DVD writer. (Or enter the BIOS by pressing F1 (IIRC) repeatedly on start up. Make sure that the hard drive is the boot disc.) While in the BIOS, you can check if the hard drive is recognized by the motherboard. If you don't see the disc listed, recheck the data and power cables.
If the hard drive was working before you replaced the dvd drive, you may have changed the master/slave assignment on the drives (if they are both IDE). Remove the drives from the computer and check the jumpers. (These will depend on the manufacturer. Use either cable select or master/slave as needed) The boot drive should have the jumper set to master or cable select. In the case of cable select, the boot hard drive should be connected to the black connector. The slave drive goes to the grey connector.
If you connected a SATA drive, try swapping the SATA ports (SATA 0 or SATA1) that has the optical drive connected to it.
The next thing to try requires either the Windows install or upgrade disc for your version of the OS (including the Service Pack) or a third party partition manager/repair utility disc. You'll need to reset the boot order to boot from the optical drive (or press F12 on starting the computer). Use the Recovery Console (for the Windows disc) to find any existing OS installs on your hard drive and attempt to repair the master boot record or boot sector if it still exists on the drive. Please add a comment with your OS for specifics on using the Recovery Console. (I replaced my WinXP with Win7 and the methods are different.)
You may have been unlucky and had the hard drive fail while you were working in the computer. See if the recovery partition (F10 on boot) still works or use your system image (Rescue and Recovery DVDs) will restore your computer to the last backup. Try doing the restore to a new hard drive if the recovery discs don't work.
I hope this helps. Please add a comment with any comments that will help me give more specific assistance for your missing OS.
Aug 09, 2012 | IBM Computers & Internet
Compaq desktop persario xp non-system disk or disk error
This means that the system identifies the hard drive on your computer as one that is not bootable, in other words, it does not contain any operating system, or it does contain one, but the disk format is not recognized by the system. For example, Windows operating systems only identify two types of disks and that is DYNAMIC or BASIC. If a Hard disk has an operating system and has been converted to DYNAMIC, you can not start any operating system on it. Only BASIC disks can be used to start an operating system. Here is a solution for you... Get a copy of the operating system you are using and boot the computer from it. Press F2 when booting and go to the system BIOS where you are going to configure the boot order or the boot sequence and make the CD drive the first booting device, so that the system can boot from the CD. If you receive a message stating that the SETUP can not find any hard disk installed.... then there must be a problem with the Hard disk format. Remove the hard disk and connect it to a desktop computer as a slave. This will enable you to see the Hard disk as a removable device on the 'My computer" menu.Go to start, right-click on "My computer" and select "Manage". This will take you into computer management console, then select "Disk management" and this will bring all the disks and drives connected to that computer and all their respective information. Click of the drive that you just connected and check on the bottom middle column, the type of the disk whether it is DYNAMIC or BASIC. If it is Dynamic, then you have to covert it back to basic. Make sure you make a data backup before you do this. This is because the system will delete anything on the hard drive. When you are done, take the hard drive back to your computer and boot from the CD again and install a new operating system. You should be good after this...
Mar 23, 2012 | HP Presario Computers & Internet
I have a Samsung NC10 which one morning stopped working. Can only get screen with option Safe mode etc. None of the function keys work and I can't do a thing. Please can somebody help.
I suggest you remove the Hard drive from you laptop (If you are not sure how to do this, get a computer technician). Get another computer, a laptop or a desktop and connect your hard drive as a slave. Then restart the other computer so that it can detect the newly connected Hard drive. Go to the Microsoft Website and download Emergency Rescue Disk (ERD) for your operating system. Write is on a disk using any burning software like Nero. Put the cd in the cd rom for the other computer and boot from it. When you are logged in into ERD, go to My computer and identify your hard drive. This is the point where you can save your data onto the computer from your hard drive, you can as well save the drivers. Then go the Administrative tools or tasks available to you from the start menu, then choose a command called the Disk Wipe. This will wipe away all the data from your hard drive. When you are done, take the hard drive to its computer and install a fresh operating system. If you do not need to save any data from your hard drive, then you do not need to use ERD, just boot the other computer with your hard drive connected Then go start and right-click on My Computer and go to Manage. Then go to Disk Management. In the Disk management, right-click on your hard drive and select format. Use the default settings and make sure that it is formatted with NTFS.
Feb 21, 2012 | Acer Aspire Computers & Internet
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Mar 31, 2009 | Computers & Internet
ZD8000 wont boot up.
Well, since the check disc failed, you will need to start by replacing the hard drive. The hard drive failure has created something different in it's behavior, the machine perceives this difference as something new, therefore causing the newly connected hardware error. Once you've replaced the drive, at start up, where you see the prompt to press F10 to go to set up, there will be another prompt there telling you what to press to go to the boot menu. If you can't get to the boot menu, then you will need to change the boot order in the set up so that it boots from the CD before the hard drive.
Jul 16, 2008 | HP Pavilion zd8000 Notebook
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive Logo
78 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
