Question about Garden
Old craftsman model 358352151 with 145 blade - starts with fuel added to carb but will not continue to run - new fuel line, fuel filter and gaskets - ?? why - is carb ?
  • 252 Answers
If you have good compression and spark and spark at the right time and mufler and ex port are clear and you have rebuilt the carb correctly and fuel lines are not pinched anywhere
check you have put the pump diaphram on 1st then the gasket and cover, and made sure the inlet screen is clear
check you have set the meter lever flush with chamber floor and have fitted spring under the lever correctly
and fitted the gasket then then metering diaphram and the cover
lo and hi screws should be set to 1 1/4 turns out from lightly seated as a base setting
check the manifold gasket and carb gasket for a air leak or a crack in insulator block
then check for a air leak at base joint or crankcase seals
2 strokes crankcases need to be air / vacuum tight in order to draw in and pump mixture let alone operate carb diaphrams
always remember F A C T S
F = fuel A =air C = compression T = timming S = spark
then primary compression ( ie air tight cases)
have a recheck and let me know what you find
cheers pauly46
Posted on Sep 10, 2010
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
Even when I prime my 32cc craftsman weed eater. it will not start. i spray carb. cleaner in the carb. it will start and stay running. The problem I guess is cold starting problems. Any help would be...
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, --
Feb 20, 2012 | Garden
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman convertiable, 32 cc line trimmer that will not stay started. have tried everything. serial number 9mtds0324sooc
My work and research show that most problems of this type are fuel system related. There is no "miracle" cure to keep the 32cc engine running. Many different things come into play here. The most common problem is dried out parts inside the carburetor. There is a small gasket and diaphragm kit to cure this however.
Your fuel system must be fairly new and with a clean fuel filter inside the fuel tank. The old fuel lines tend to become brittle and flakes of them break off and enter the carb. They get lodged on a very small screen filter that allows fuel to flow thru the carb.If fuel lines are old or brittle, replace them.
Another problem is that the carb has gone "out" of adjustment or never was adjusted correctly in the first place (not uncommon). With new, stringent EPA and CARB laws and regs, the manufacturers of these carbs set them to run very "lean". This means a lot of air and very little fuel. The problem here being that the lubricant for the engine (in this case) is IN the fuel.
Check the condition and color of the spark plug. It will tell you how the engine is performing. Clean the black carbon off of it and reinstall, or just put a new one in.
So brittle fuel lines, old, stale fuel, clogged up screen strainers inside carb, weak spark and misadjusted carbs can ALL contribute to your machine's problem. It is NOT rocket science but some standard diagnostics and testing is required to narrow down exactly what the problem is. Take a look at the things I have mentioned and remember, I have no idea how OLD or in what mechanical condition your machine is (even though I own one just like it). Post back as needed.
Sep 04, 2011 | Craftsman Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Craftsman 3.3, will start, run on 3/4 choke, thought was carb problem, so i replaced diaphram, gaskets, still same results? any suggestions? thanks
These are know for the fuel line problems. Pull out the fuel line from the tank with the filter and check it. I've fixed 4 or 5 with bad lines.
While your add it you may want to install a new filter.
Aug 07, 2010 | Craftsman Garden
Mower has to be chocked to run
Oftentimes, this problem is the result of mowers left outside in ambient air that is high humidity. This, in turn, allows algae to grow inside the carb fuel float bowl and/or inside the fuel tank if left out for extended periods (one month or longer). Also the same thing will cause air filters to clog rapidly with mold and mildew - slowly at first, then more rapidly as the mold continues to grow. Get out the carb cleaner in spray cans and go through every ported passagewway in the carb body then reassemble using CLEAN screws, gaskets and all interrior parts. Any residue mold or mildew will continue to grow - and it can grow in gasoline!! Imagine that!!
Jun 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman weedeater will not start
The most probable problem is no fuel delivery to the engine.
1. Check/replace the fuel in-tank filter, you should be able to easily blow through it once removed. The primer bulb will sink down and not return quickly if the filter is bad. Fuel will not return to the tank via the return line if the fuel filter doesn't allow fuel to be pulled in.
2. If fuel is returning to the fuel tank when the primer is pushed then your problem is inside the carb.
3. To verify this put a small quantity of gas in the lid of a water bottle (half full). And pour it into the carb throat. Replace the air filter to prevent a backfire from shooting flames out. Try to start the weedwacker. If it runs and then dies the problem is inside the carb.
4. If you are really good at working on things with small parts you can clean out the carb and replace all of the gaskets to solve the problem. If this isn't for you then you should take it to a lawn shop and have them clean the carb and replace the gaskets.
NOTE: Replacing the gaskets is very important because the gaskets get stiff and the fuel pump action of one of the gaskets is reduced or stopped.
Hope this helps, Karl
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
