Question about Sony VAIO VGN-FW140E/W Laptop
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix it.
  • 2,567 Answers
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 19, 2010
Vaio replacement battery "plugged in. not charging"
For this kind of issue, you may try the following troubleshooting steps for confirmation:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure your vaio vgn-cr510e power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Dec 24, 2012 | Sony VAIO VGN-CR510E/P 14.1" Laptop
Sony vaio not charging while charger plugged in
Seemingly your laptop dc jack is dead. How to confirm it? If you should wiggle your laptop charger on a position to let your laptop charge, it indicates your dc jack is loose. Either replace it or repair it. If your dc jack works well, please check your ac adapter. Maybe your charger is dead.
http://www.chargerbuy.com/laptop-ac-adapter/sony-ac-adapters.html
Oct 27, 2012 | Sony VAIO VGN-NS160D/W Notebook
I want to know the BIOS password for my laptop model No VGN-FW140E
To reset the BIOS read the information from this link.
In case of your Sony Vaio laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 07, 2010 | Sony VAIO VGN-FW140E/W Laptop
My grandaughter's Sony VGN-FW140E laptop will not boot up after being turned off unless it is unpluged from adapter, the battery removed, allowed to sit idle for 3 or 4 hours then put the battery back in...
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
5. The power button could be bad.
Sep 14, 2010 | Sony VAIO VGN-FW140E/W Laptop
I want to reset password Bios of VGN-FW140E. How can o do? Please help me. I need a backdoor passwords.
Sir,
if you can open your laptop search for jumper in the laptop and remove it and turn on you laptop the password will be removed and you will be able to enter in you system again and now if you want to plug it in back you can do that to.
Nov 11, 2009 | Sony VAIO VGN-FW140E/W Laptop
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony VAIO VGN-FW140E/W Laptop Logo
995 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
