Question about Braun Health & Beauty
How do you open a Braun 360 razor? - Braun Health & Beauty
  • Braun Master
  • 1,623 Answers
Remove the 'cap' on the bottom that surrounds the cord inlet by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will pull away revealing 4 screws. Remove the screws to seperate the front and back of the shaver and access the insides.
If needed, you will find parts for this model at shaveroutlet.com
Posted on Sep 10, 2010
Can anyone help with some advice for home razor repair?
After dropping the razor it is very difficult to know what the problem is without examining it. Based on the symptoms you describe, I would guess that the the 'drive unit' is damaged. You will find this part available at shaveroutlet.com. See link below. Scroll down the page for installation help video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Oct 26, 2011 | Braun 360° Complete 8985 Electric Shaver
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Jun 12, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
I have 3 Braun razor. My best one is my 1-2-3 system one. But an electric prong is broken. Where can it be fixed ? I entered beleow Braun 360 just because 1-2-3 system doesn't apear as a valid option.
Try Electric Shaver Service in Nebraska. 1-888-476-1785
They can give you an estimate and are reliable and usually repair razors in under a week from time of receipt.
Hopefully you find this Very Helpful and best regards!
Jul 10, 2009 | Braun 360° Complete Electric Shaver
EMPTY!?!?
The "empty" light is for the cleaning solution. It needs to be replaced with a new clean cartridge. There should be a big button on the back of the cleaning unit which opens it up and allows you to replace the cartridge.
Jul 02, 2008 | Braun 360° Complete 8985 Electric Shaver
Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Sep 12, 2007 | Braun 360° Complete 8985 Electric Shaver
Health & Beauty Logo
73 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
