Question about ButtKicker BKA1000-4A Amplifier
The BKA1000 is not currently available. What would be a good alternate product solution for this amp? It needs to power four buttkicker LFEs with 500W into a 4 Ohm load. Any suggestions would be greatly appreciated.
  • Scott Frye
    Scott Frye Sep 14, 2010
    Is this for home use or Pro??
  • grivera826 Sep 14, 2010
    Home use.
2 Suggested Answers
Grubhead
  • 5158 Answers
SOURCE: Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Posted on Apr 02, 2010
Testimonial: "Much appreciated; clear direction. Thanks."
Explain the difference between static electricity and current electricity
Static electricity...
Generally considered a nuisance... can cause serious damage to electronic equipment... (it is STORED power)
Thunder & lightening are STATIC electricity...
Wiki definition included (below)
For commercially available ELECTRICITY...
(usa) "currents" ... All electricity functions because of a DIFFERENCE in potential. When you start adding wires then you are harnessing that potential DIFFERENCE into usable energy.
Direct current & Alternating current... Generally referred to as "AC" & "DC"
Most all of the power grid you are looking at on power poles around your community... have "AC" flowing on the power wires
good for powering residential housing and commercial power applications
Immediately below those wires ... The phone wires
have to run about 10 feet below the "AC" wires...
Phone systems run on "DC" because it is quiet
(communications systems).
Alternating CURRENT can be rectified into Direct...
and Direct CURRENT can be inverted into Alternating.
Generators,
solar panels & BATTERIES output DC
Which can be accumulated and stored.
Alternators
output AC... and because AC is less susceptible to magnetic interference... it can travel great distances with very little loss.
Very interesting topic for further research ... and the principals of both... as argued by no less than Nicola Tesla & Thomas Edison.
Hope this helps
Static electricity
Carnac the Magnificent
Apr 10, 2017 | Televison & Video
I took my 1000 watt amp and kit out of my old truck and put it in in my new ride. It worked just fine at first then the subs started going out for hours even days but amp was still powered on then i hooked...
You may need to run a larger wire to the amp or upgrade your alternater to get enough voltage to the amp. double check all of you wire connections going to the battery and from the alternator also. Clean all terminals and maybe even beef up the wires from the alternator to your battery. Your smaller amp works due to it needing less current to work, your big amp can't even power up with the lack of available current.
Apr 01, 2013 | Car Audio & Video
My amp and system works fine with the car on acc but when the car is running , the amp started smoking and it goes into protect mode
Your amp is trying to make up for the lack of available voltage that is being used by your car and to a maintain output it will then start to draw more current to accomodate the drop. The formula that shows the proportions of Voltage (Electricity) and Amperage (Intensity) to Watts (Power). It looks like this P=IxE So if your amp is 1400watts and it's getting 14 volts it will take 100 amps to power it (given the amp is 100% efficient, which no amps are) so when you turn on your AC that puts a load on your motor and alternator too for the fan and the compressor slows down your alternator making the voltage drop down to 10 volts with everything full blast. That means you amp is now pulling 140 amps of current to make up for the voltage drop, Your wire that is going to the amp is probably getting pretty warm at that time also unless you have 4 ga or larger. So when the voltage gets too low the amp will turn off and go into protect mode to keep the current in the rails from getting the amp so hot it will eventually cook the components inside of it. You will be looking for a higher output alternator just like everyone else who has high powered amps.
Mar 31, 2013 | Directed 2400d Car Audio Amplifier
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
Just hooked up fosgate bd1500.1 to 2 JBL gto series 15" subwoofer
Your current alternator is strained and cannot give the required current draw of your amp. Most aftermarket amps have exterior fuses. Try adding these up for a round-about current draw number. I would bet that your amp is killing the availible power from the electrical charging system of your car. You could always go up to a higher fuse, (I run a 200 amp breaker) bu this will only make your stereo work and your alternator fail prematurely. Try searching ebay or go to ohio generator for a stronger output alternator.
May 03, 2009 | Rockford Fosgate Power 1500.1BD Car Audio...
Control the volume on each of the 12 bass shakers i plan to install
Please note that you can't simply wire them together in series or parallel. Connecting any more than 2 would likely cause damage to your amplifier. (depending on the impedance of the bass shaker 4 ohms, 8 ohms, etc.)
The Buttkicker brand recommends the following configuration for four buttkickers into one amp: Click here
As you can see, you need a combination of parallel and series connections to make sure the amp is "seeing" the correct load. I'd recommend purchasing three dedicated subwoofer amps (there are some good inexpensive ones at http://www.parts-express.com.
This will give you volume control over each set of four shakers at the amp itself. If you need control at each shaker, the only solution I know if is to use an impedance matching volume control.
Check Parts Express for those, too.
If this solved your problem, please rate it as FixYa. If not, let me know how else I can help you.
Apr 21, 2009 | Audio Players & Recorders
ButtKicker BKA1000-4A Amplifier Logo
Top ButtKicker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ButtKicker Audio Player and Recorder Expert? Answer questions, earn points and help others
