Question about Sanyo DP19649 LCD TV
My old pc needs drivers to use the Sonyo dp19649 tv as a monitor. the screen goes black after the Windows XP logo goes off. Need download, not purchase a driver program. thanks, JP
4 Suggested Answers
  • 7 Answers
SOURCE: When i first turn on the tv it displays the
First make sure your HDMI cable is connected from the Cable to the TV; then on the TV Menu check the input; should have a choice of items like, Air, Cable, HDMI, Aux...if you do have an HDMI cable connection, select HDMI and indicate which port #; it could be listed like HDMI/DTV 1 or HDMI/DTV 2; good luck
Posted on Aug 11, 2009
SOURCE: need a remote code my new sanyo tv to go with
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
Posted on Sep 13, 2009
  • 32 Answers
SOURCE: Need to program a GE Universal remote for Sanyo
http://www.remotecodelist.com/remotes/old-index.html
in this page you need read step by step for solved you problem...
bye
Posted on Mar 07, 2010
Tv monitor went blank when using my pc on it
try adjusting your resolution before you plug the tv into the pc. a 26" shouldn't cause this problem, but it may. Give it a try. If this doesn't work, try finding a driver on the Sanyo website for that pc and download or repair the existing driver. You'll need to use another monitor, of course. I hope you have one.
Dec 31, 2013 | Sanyo 26in LCD 720p HDTV - LCD TVs
Screen goes black just after windows logo on a E-SYSTEM sorrento 1.
Your monitor display settings are no longer set (synced) with the upgrade. Boot into Safe Mode by pressing F8 during boot and lower the screen resolution.
You will have to check Display drivers in Device Manager, and make sure they are loaded.
Sep 25, 2012 | Computers & Internet
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
Computer boot up
This looks like a problem with you video card drivers. I had this problem last week! ;o) The screen turned off while in the Windows logo.
You need to boot in safe mode and reinstall the drivers of your video card.
TO BOOT IN SAFE MODE :
Boot your computer and tap F8 every seconds. If you get to a blue "boott selection screen", press ESC, and restart pressing F8 every second. You will get to a black windows selection menu with the arrows. Select the boot in safe mode option and press enter.
ONCE IN SAFE MODE:
In XP, once in safe mode, you PC will boot with minimal settings and default drivers. Go to START, CONTROL PANNEL, SYSTEM, HARDWARE, DEVICE MANAGER. You should see your display adapters in there. If one has a yellow exclamation mark, then you need to re-install the drivers.
TO REINSTALL THE DRIVERS:
You need to find the graphic card CD you had when you purshaed it, or download the drivers on the internet. Go to a friends house, and download them on your manufacterer's website (ie : ASUS, ATI, etc.). You need to know your card's model name for that. It should be in the Device Manager, where you looked earlier (Ex: ASUS MAGIC 128MB)
Once you reinstall the drivers, you should be ok.
Worked for me. It makes sense because the screen turns off when it tries to load the currupted drivers.
I hope it helps.
Dec 31, 2008 | Computers & Internet
Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
Dec 20, 2008 | HP Pavilion zd8000 Notebook
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
After installing XP driver Computer dont boot after showing the windows logo. Monitor goes to black screen like standby mode. I tried various version of driver for this card. but it does not work. But...
I sound like the the driver corrupted some of your system files. Can you boot into safe mode and perform a system restore to before you installed the driver. If that works make sure you download the newest drivers from the nvidia website.
Mar 20, 2007 | Evga e-GeForce 6800 (128 MB) Graphic Card
Sceptre D50X black screen
If a monitor shows a normal screen at startup but goes bad after the Windows logo disappears, your Windows video setting is probably not compatible with the monitor. You can start Windows in safe mode to select a compatible resolution for your monitor.
Aug 16, 2006 | Sceptre Dragon Eye D50X (White) 15 in.CRT...
Sanyo DP19649 LCD TV Logo
256 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
