Question about HP Laserjet Cp2025n Printer
Anything that prints in color is shadowing. Could this be a fuser problem?
  • 223 Answers
If you see a grey background it is def the fuser. If its a miss print. it could be the color density sensor. and would be fixed by replacing the transfer belt.
Al
Posted on Oct 01, 2010
Print appears on multiple pages
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
Dec 20, 2012 | HP Color Laserjet 3550 Printer
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
Getting shadowing on print out?
shadowing or ghost printing is usually caused by a fuser that is not running at its opperating temperature the fuser is the problem about 85% of the time. the thermistor is directly responsible replacing this part will clear up the prolem or repace the whole fuser depending on the wear. toner cartridges can also do this for the toner to do this its usually a expose drum has been set down on a dirty or rough surface thus compromising its surface
May 20, 2010 | Lexmark Optra T612 Laser Printer
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
Shadow printing with Blue color. C350
sounds like you may be getting ghosting from the fuser unit upper heat roller may be worn
Dec 03, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Lexmark Optra SC1275 printer smears
Looks like a problem with the laser unit or the drum unit or both, which may have to be replace. The website is correct. Best call for service.
Nov 13, 2008 | Lexmark E320 Laser Printer
PRINTING IS SMEARY AND NOISY
If there is a clicking noise as the printer is printing then most likely the fuser film has torn. The fuser film is part of the fuser unit. This item is best replaced by a technician.
Have you found pieces of film like material around the printer paper exit? It is most likely a dark grey color.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
HP 2600n Printer Problem
Sounds like the fuser assembly needs to be replaced. This is a supply item that you can order from HP
Sep 25, 2008 | HP Color LaserJet 2600n Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
HP Laserjet Cp2025n Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
