Question about Northstar Pressure Washer 3000 PSI
Ive got a north star pressure washer 2500 hpw with a commet pump model number lwd3025.I need new seals and pistons can you help.
david04928
  • 102 Answers
SOURCE: north star petrol pressure washer.
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Posted on Mar 15, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
  • 174 Answers
SOURCE: oil leak at top of pump
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Posted on Sep 10, 2009
  • 68 Answers
SOURCE: Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
Posted on Jun 10, 2010
  • 905 Answers
SOURCE: I have a NorthStar pressure
NorthStar is a Northern Tool housebrand. You can contact them using the information below, and order the parts that you need.
Contact a Northern Tool Product Expert:
Call 24/7: 1-800-221-0516
Alternatively, you can also order directly from the pump manufacturer (Comet Industrial Pump) at cometpump.net
Of their home page, there is a link to a Parts PDF and a Repair Manual PDF as well.
Posted on Aug 31, 2010
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
SEEPS GREY OIL
May be time for re-seal kit. Usually, water leaking into crank case of the pump will mix with the oil /grease and produce gray looking foam. This grey looking substance still has lubricating properties but is a sign that the seals are failing and allowing water to enter the crankcase. The water can enter thur /past the piston seals or thru crack in the chamber. On some high pressure pumps, there is space between the rear is the piston/cylinder area and the oil/crank case. This space will allow water leaking past the cylinder seals to drain out of the pump and not enter the crankcase. In any case, water or oil leaking out of the pump is not normal. If your pump has several hundered hours of use, check on ebay for complete replacement instead or rebuilding (rebuilding a pump is not always successful, for reliable performance, replace the whole pump with same or upgraded model ). Good luck
Dec 18, 2011 | Karcher 2500 PSI Pressure Washer
I have water in the oil in the comet pump/ZWD 4030. It is on a North Star 3000 hpw.
You have a seal failure, you need to reseal the pump and change the oil in the pump.
Nov 04, 2010 | Northstar Garden
Oil leak at top of pump
Sep 07, 2009 | Northstar Garden
Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
May 19, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer won`t pressure up
Dear rustrick281,
It seems that your pump needs a good service. The sucktion and delivery valves got faulty. The high pressure seals and the low pressure seals must be renewed. The pistons must be checked for corrosion and cracks. Also the pistons or one of the pistons got stuck due to oncorrect lubrication. The swash plate that drives the pistons could have got loose. So the motor turns and the pump stays dead. So a good examination and service must be done to the pump. To renew all the parts I have mentioned, you must buy a PUMP KIT for you model. The pistons are not included in the pump kit....but hopefuly the pistons are still good. Also the oil inside the pump must be renewed.
Regards,
Fulltech.
May 04, 2009 | Campbell Hausfeld 1800 PSI Electric...
Water in oil
Dear akwelectrica,
When a full kit was installed....WHAT was installed??? Were the OIl seals replaced?? Were the Low Pessure Seals Replaced?? Were the high Pressure Seals Replaced?? Was the OIL changed?? If the oil was changed...did all water in the oil compartment been removed?? Also did the suction and delivery valves were replaced?? Now if all these things were done, BUT the pistons were not changed, than the whole kit was done for nothing!! My suspicion is that the PISTONS were not changed. But if all the kit was used and even the PISTONS were changed, than you must for sure have a cracked or damaged head. When I say the HEAD...I am always refering to the part that holds the pistons. But in rare circumstances even the outer head could be damaged. Ask your "Service Tech" what he replaced and you will know the answear. As I said..I suspect that the PISTONS were not replaced by New Ones.
Regards,
fulltech.
Apr 03, 2009 | Karcher 2500 PSI Pressure Washer
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
My Karcher HD 1050 DE has lost pressure, ive had new valves put on it but still has no go in it
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Oct 12, 2008 | Karcher 2500 PSI Pressure Washer
Northstar Pressure Washer 3000 PSI Logo
119 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
