Question about Bosch Washing Machines
Change the motor brushes on a bosch WFL 2000 - Bosch Washing Machines
  • 139 Answers
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
SOURCE: changing the brushes when the motor is off
how do you remove the brushes on a Bosch Classixx 1200 washing machine?
Posted on Jul 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch WFL 2060 GB - The Drum does not rotate, I
Welcome to fixya.
Follow this link and though it may differ slightly, the procedure is the same.
http://www.fixya.com/support/r5082734-yes_change_some_bosch_washer_motor
Thanks for choosing fixya and good luck.
Regards,
Macmarkus :)
Posted on Oct 22, 2010
I want to replace the brushes on a Maxx WFL 1600 washing machine. how do i extract the motor from the appliance?
Welcome to FixYa.
Changing brushes in your bosch compact washer ?
Try out my tip...
Let me know how you make out.
Regards,
Macmarkus :)
Sep 21, 2010 | Bosch Washing Machines
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Apr 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I want to change the brushes on my bosch washing machine
Some bosch you can buy cabons brush on its own cost £10/£25......Some models you need to fit half motor with brushes located within, cost of parts £60 approx from espares.co.uk
Feb 23, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
How can i remove the motor in order to cahnge the brushes? pleaseon my bosch wfl 2860 gb washing machine
The best way to do it is to disconnect the washer from the water supply and electric socket.
Lay the washer on it's side, and remove the rear cover and drive belt.
Undo the 2 screws that secure the motor in place, unplug the motor lead, and earth lead.
Prize the motor away from drum.
Change the brushes.
Please rate my solution.
Thanks.
Nov 21, 2009 | Bosch Washing Machines
Bosch wfl 1800 starts filling then stops with a ticking/clicking noise near controls
motor brushes are probably worn out will need replacing not expensive but have to remove motor to get at them.
Oct 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2450
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
