Question about Whirlpool LER4634J Electric Dryer
Hi, I had to change the outlet plug that came with this dryer for the plug that my old dryer had because It was different Then the outlet on the wall. Now my question Is, Is the dryer suppose to spin clockwise or counterclockwise when drying? Thank you..
  • Whirlpool Master
  • 43,501 Answers
Changing the plug on a single phase dryer will not change that... no way no how...
heatman101
Posted on Sep 10, 2010
  • Lee Reinertsen Sep 10, 2010
    Ok Thank you. But my question still Is which way Is It suppose to spin, clockwise or counter clockwise. Would really appreciate a answer.
    And again, Thank you..
  • D. Floyd Kolb
    D. Floyd Kolb Sep 10, 2010
    Honestly I never paid much attention to that...the insides are made so that they are not direction sensitive...it seems to me that most go CCW though...
    heatman101
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
New house had dryer outlet that electrician installed a Range outlet ( 30 amp breaker) by mistake on the wall. I changed my cord on Samsung dryer to match the outlet and dryer made a loud noise and would...
You still do not have one of the wires hooked up right...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 01, 2011 | Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
I am getting a cabrio dryer today and i have a regular home outlet where my last dryer was, can i use the old cord on the new dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Whirlpool Dryers
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Landlord wants to know what type of plug is on my dryer. Dryer is in storage. Dryer is about 8 years old. Is there a common type?
It's either a three prong or four prong plug. He'll need to change the outlet to match the dryer or change the dryer plug to match the outlet.
Oct 23, 2009 | Dryers
I don't have the same plug as the one on my kenmore 70 dryer
Hi, You can either change the outlet or change the cord. Easiest would be to get a new caord. Make sure you get the right one. There are two different ground posts.
One is straight and one is L shaped.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
