Question about Radio Shack Accurian ADR-3223
I need a remote control for this unit - Radio Shack Accurian ADR-3223
  • Radio Shack Master
  • 8,457 Answers
Try website like Remotes.com to buy an exact remote to the original or very close compatible to the original.
Posted on Sep 09, 2010
What is the problem E4
Using remote control "on" the unit, then push the C button of remote control, if the C display at the unit "off" the unit using also the remote control. Unplug the power supply then plug again and start the unit using the remote control.
It the instruction above don't solve the problem, the return air sensor is out of range or the main board of the unit itself is defective. You need a qualified tech with this problem
Jun 02, 2016 | Dishwashers
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Jan 15, 2009 | Heating & Cooling
Philips universal remote control
first you will need to find the model number of the universal. look it up online for the manual and code book. you should probably get the original remote that goes with your unit. type in the model number of your unit in the search on ReplacementRemotes.com and find the OEM remote.
Dec 21, 2008 | Philips Magnavox Learning Universal Remote
Need remote code for rca dvd/vcr combo using a sharper image univeral remote
Use code search on your Sharper Image remote control to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 24, 2017 | Televison & Video
AIR CONDITIONER REMOTE
- Check if the battery is ok.
- Some remote control have reset button, you can find it at the front or back at the compartment of the battery push the rst button with pin or ballpen to reset it and try.
- Some remote control have selector switch in both remote control and at the board inside the unit. Try to transfer the switch button from A to B and also at the board inside the unit and reset the remote control and try.Or need to reconfigure the remote control to select the frequency.
- Try your remote control to other unit with same brand as yours to confirm if your remote control is really need a replacement. If it works then your receiver board in the unit is need a replacement. Or if wont work then you have to buy a new remote control. But if you have no budget then try to switch on the unit using emergency button to operate the unit.
Dec 26, 2007 | Heating & Cooling
Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
Radio Shack Accurian ADR-3223 Logo
79 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
