Question about Cars & Co Walbro Wt603 Carburetor Pocket Bike Scooter Baja 5b
Hi i have a problem to start my Rovan Baja 5b 30.5cc engine up,i followed all the instruction with engine start trouble shooting manual.....it seems to me that the fuels not coming thru the Carburetor,even when i prime the engine and using the choke it still doesnt start.....................
Baja warrior 196cc mini bike engine torque specs ???
Hi, Randall for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Baja MB 200 Operator Manual
Baja Mini Bike Parts Baja Heat Parts Baja Mini Baja Parts
Mini Bike Easy Governor Bypass 1080P
http://docsfiles.com/pdf_baja_bike_manual.html
Mar 22, 2016 | Motorcycles
Code 4 and engine lite on
If the check engine light is on there will be OBDII and manufacturer specific codes. These codes start with a letter and are followed by four numbers (P0304 for example). These codes can only be read by an OBDII code reader or a scan tool. These are the codes you need to get in order to start trouble shooting your vehicles problem.
Apr 06, 2015 | 2011 Chevrolet Impala
Switched stock pipe to dominator and got one normal start. After that run cut motor off and it hasn't started again since. I've cleaned carb and replaced spark-plug but, NOTHING seems to help!
First, put the old pipe back on to see if it runs again, this will confirm if there's any engine damage. If it runs ok (will probably take a few attempts after having a problem like this) and you are desperate to use the new pipe, you may want to change the fuel mix to something less lean.Hope this helps.
Apr 27, 2011 | Trango Hpi Baja 5b 1/5 Scale Rtr...
I am having trouble buttonholling on my Janome, it is new. It starts sewing and then stops and blinks 6L. What have I done wrong
Check your manual and follow the instructions. The error message may be listed in the trouble shooting at the back of the manual.
Probably will need to put on the buttonholing foot, pull down a lever which guides the machine to sew the length correctly and choose a buttonholing setting on the stitch selection.
Also, for good buttonholes, always interface the fabric to give it stability.
Mar 28, 2011 | Janome 8080 Computerized Sewing Machine
1995 toyo camary that runs like hell
Several things can cause this. 1. Your engine is overheating because it is low on Coolant or Oil. 2. Your water pump is not working correctly and the engine is overheating. 3. You have stuck valves or blown head gasket. 4. Your block or Head is cracked. 5. Your Thermostat is stuck. Each of these has it's own trouble shooting steps and repair procedure. I recommend you get the Haynes repair manual for your make and model of vehicle to get a good reference for the trouble shooting and repair you will be doing. It has diagrams, step by step instructions and pictures of the repairs you'll be doing as well as testing procedures. You can get this from Auto Zone or just about any Auto parts store.
Dec 12, 2009 | 1997 Dodge Ram 1500 Club Cab
Baja 5b lacks power
Replace batterys or charge them.
Nov 21, 2009 | Trango Hpi Baja 5b 1/5 Scale Rtr...
196 cc baja mini bike dies if I try and give throttle
Well i had the same Baja mini bike and to be honest with you, you will run into alot more problems with that bike bec they build them so cheap, I and alot of others had 1 thing go after the other on that modle and to me they just aint worth the trouble or money, But check the coil and make sure to
Jul 21, 2009 | Mini Motorized Bike
Cars & Co Walbro Wt603 Carburetor Pocket Bike Scooter Baja 5b Logo
356 people viewed this question
Top Cars & Co Toys Experts
Adam Fjeld
Adam Fjeld
Ellen Tumey
Ellen Tumey
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
