Question about Maytag Refrigerators
MAYTAG PREFORMA FRIG. PSD262HLEW EVAP COIL FREZZEING OVER FRIG SIDE NOT COOLING REPLACED EVAP FAN STILL HAVE SAME PROBLEM
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Why is my condenser freezing up, but my frig isn't cooling right? could it be the thermostat? Or is the condenser flooded?
when the evap ( the coil inside the freezer freezes up it blocks the coil causing no cold air to flow to the fresh food side. . the thermo is ok but the aditive defrost control or the heater or defrost terminator is or has failed .. mm ( you do have a defrost problem .. mm
Aug 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
My side by side maytag refrig only cools to 60 degrees on the refrig side...... the circulation fan is working....however the coil had been frozen over with ice. I defrosted it but still the frig only...
Your refrigerator has an Adaptive Deforst Control located in the control panel inside the fresh food section part number 61005988 is is the most likely reason for your trouble. Picture #13 below.
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Refrigerator not cooling but freezes
You might try vaccuuming under the frig to clean the coils so it could disapate the heat more. This could cause that sytem. Also if the fan is not working.
Hoped this helped. If not let us know.
Mar 16, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
65 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
