Question about Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up
How to replace a power steering hose on a 2000 Infiniti I30.
How do I tell if my 96 i30 has electric suspension I'm trying to replace my power steering pump
electric suspension not likely on a 1996 model
std macphearson struts should be there unless your i 30 has been after market modified
power assisted rack and pinion with the pump
what does the susoension parts listing show for the i30
https://www.autohausaz.com/infiniti-auto-parts/infiniti-i30-repair_manual-replacement.html
May 02, 2016 | Cars & Trucks
2000 Infiniti i30. Where can I get a vacuum hose routing diagram?
Car forums by make can be a good source of these diagrams. Join an Infiniti forum.
Jun 18, 2015 | Nissan Cars & Trucks
Infiniti i30. Where can I get a vacuum hose diagram?
Hi Marie, I searched "vacuum hose diagram Nissan Infiniti i30" & came up with a fair number of hits including what seem to be actual diagrams. All that's needed is to expand them to useable size.
Infinity problems
Yup. Could be the belt came off and jammed somewhere, OR the compressor locked up and the belt started slipping till it burned in two.
Jul 23, 2014 | Carbotech 2001 INFINITI I30 CT900-XP12...
My i30 t infiniti 1996 heater doesnt blow hot air and also car overheats when it goes over 45 mph
Sounds like your just low on coolant. If not low on coolant, possibly a bad water pump or lower hose is collapsing when warms up.
Jun 18, 2014 | 1996 Infiniti I30 Water Pump 96
Why my Infiniti 2000 I30 sunroof does NOT open or close ?
You may have a blowen fuse, or a bad switch, or a motor that has stopped working.
Jun 08, 2014 | 2000 I30 Sunroof Motor
Infinity 2000 i30 wine i start speeding up around 30 to 35 my car fills like it going out of control wy
is the noise going overtop of even your radio? how long has it been doing this? when you turn the steering wheel right or left does it go away?
from just your above issue it sounds like a wheel bearing is going on your vehicle but would need more information to be precise.
May 05, 2014 | 2001 Infiniti I30
Filtro de gasolina
Quiero saber donde queda el filtro de gasolina de un infiniti I30 modelo 2000
Nov 30, 2013 | Cars & Trucks
2000 Infiniti I30 blows fuses
NO ITS JUST A POWER SERGE THE WILL HAPPEN TO AVOID THAT TAKE THE BATTERY GROUND OFF NEXT TIME BEFORE REPLACING THE FUSE ;IF THE FUSE BLOW AFTER THE GROND IS BACK ON CHECK THE RADIO POWER SOURCE THERE COULD BE A SHORT SOME WHERE
Sep 15, 2009 | 2004 Infiniti I35
Timing chain on 2000 Infiniti I30
timming chain not belt . its a really big job i suggest the dealer.to much work and u need a lift to do the job!
May 18, 2008 | 2004 Infiniti I35
Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Logo
755 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
