Question about Lowrance Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System
My 520c locks up, initial screen comes on but will not go any further. After a minute it shuts down.
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Lamp comes on but without picture
The color wheel is the likely problem here.
Nov 27, 2012 | Samsung HL-S5087W 50" HDTV
Zzy6913@yahoo.com i havwe a new compaq presario laptop 1800 model number a18xl390 and its locked up !!!! how do you unlock this model of laptop ?? can a nyone help thanks the wiz
Locked up screen?? Shut down with button, pull the battery. After five or ten minutes reinstall the battery, Push start button. Screen will say window shut down unexpectedly and ask for start command. Start in safe mode and prompts should come up about your problem and ask you to send a report to microsoft. Do that and follow the prompts. I hope that helps.
Jul 14, 2011 | Computers & Internet
I cannot shutdown my Windows 7 computer. It never shuts off so when I have to restart for an update, it never shuts down completely and just comes back up to the desktop.
Check if a particular program is slowing the machine when you switch on or shut down, e.g. an anti virus program.
Go to Control Panel > All Control Panel Items > Performance Information and Tools > Advanced Tools (in the left pane). On this screen the problem is sometimes shown. If not, click View Performance Details in Event Log (Event Viewer). Events in the 100 series are boot events and I believe those in the 200 series are shut down events. These can be followed up by double-clicking them, then clicking Event Log Online at the bottom.
Hope this initial information helps. Let me know for further instructions.
Thanks.
-TA
Oct 10, 2010 | Computers & Internet
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
PC starts up, afterlogi n locks up. Afr restart no signal to moni
Remove the RAM from socket. Clean the RAM contacts with pencil eraser & then refit RAM.
Hope this solves the problem..
Nov 29, 2008 | ASUS P5S800-VM Motherboard
Question
First, i suggest you try this. Remove batteries then press and hold power button for 15 seconds. Wait a further 1 minute then reinsert batteries and try again.
If no good, try this. If you can get to the MENU mode (in stored pics), scroll right to SETUP, press centre button to OK it. Scroll down to SETUP1. Scroll right, then down to initialize which will be lit yellow. Then scroll right and scroll up when ok will be lit yellow then press centre button to OK it. This will return camera to factory defaults including set up language.
Good luck !
Aug 29, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lowrance Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System Logo
26 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
