Manual for Office Depot® Heavy-Duty Stapler - Office Equipment & Supplies
Suzman
  • 642 Answers
SOURCE: I have a Swingline High
At the rear of the stapler is latched retainer(looks triangular when viewed from the side). Push it forward (toward th other end of the stapler) and lift up and back. This will release the "tray" that holds the staples.70a3245.jpg
Posted on Oct 31, 2010
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
SOURCE: instructions on how to load a swingline heavy duty
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Posted on Aug 19, 2010
puertobori
  • 7733 Answers
SOURCE: I have been unable to
Go to this link.
Posted on Nov 02, 2010
  • 474 Answers
SOURCE: What size staples for a Cobra heavy Duty stapler?
Take it to home depot or lowes, they will sell you the right ones.
Posted on Feb 22, 2011
My Bostitch 20Suite office stapler won't staple and isn't jammed
Hello, Go to this website for instruction manual download. It also will have a number u can call for tech support to talk to a person, if further help is needed. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Jun 04, 2014 | Stanley Bostitch 20SUITEBLK Heavy Duty...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
How do I load the clipper 700 stapler?
At the back of the stapler, there is a piece that you push in and then pull out. You load the staples in there and then replace the piece you pulled out.
Apr 27, 2011 | ACE Hardware Heavy Duty Clipper Stapler
Feb 22, 2011 | Arrow Fastener 8000 Cobra Heavy-Duty...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Instructions on how to load a swingline heavy duty stapler.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
1,190 people viewed this question
k24674
