Question about Toto Drake ADA Compliant Toilet with Elongated Bowl
The handle gets loose and we have to open the tank and tighten the black circle that is connected to the handle. The black circle keeps getting loose even after one flush
    Master:
    Sergeant:
  • 449 Answers
Replace the handle they are universal
Posted on Sep 09, 2010
Keeps on pumping out water from the bowl even when there is no water in the bowl
follow this steps and fix it.
Adjust or replace a flush handle:
  1. Remove the cover from the toilet tank (the higher part at the back of the toilet). If the handle is loose, tighten the locknut with a wrench. If the nut won't budge, apply penetrating oil and let it set before removing.
  2. Unhook the chain from the trip lever and slide the trip lever, with the handle attached, through the hole in the tank.
  3. Soak the handle threads in vinegar for an hour or so to remove mineral deposits, then scrub clean with an old toothbrush.
  4. Reinstall the assembly, tighten the locknut and adjust the lift chain (see below).
Adjust the lift chain:
  1. If the handle must be held down while the toilet is flushing, the chain may be too long. Shorten it by hooking the upper end through a different trip lever, or use long-nose pliers to open and remove some chain links. Alternately, replace the chain with a new one.
  2. Some flush assemblies have a lift wire instead of a chain. If the wire binds against its guide, flushing is impaired. Loosen the guide with a screwdriver, then adjust it so that the flush valve falls freely onto its seat.
Nov 24, 2013 | Home
Love our new Toto Drake II double cyclone toilets with sani gloss finish. However the trip lever handles are already getting loose on both toilets... what would cause this-- and what is the...
dalbritton-
The handles are fixed to the tank body with a hex nut on the back (inside of the tank. They may not have been tightened properly from the factory. Tighten a bit with a wrench and you're good to go!
Regards,
DIYpro
Jun 08, 2011 | Toto Trip Lever For St774S Toilet Handles
How to tighten loose door handle
should be a small access cover on the handle top and bottom pop them open with a flat small screw driver screws should be underneath
Jun 09, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Wife rode in parade, heated up, since headlight giving prob. found prob in start button corrected it but was acting like not making good connection at plug rt side of tank. was able to wiggle it and get...
You are correct: Once these connections begin to loosen, they develop high resistance and get hot. This tends to increase the resistance through the connector even more until something melts or corrodes - and fails completely.
Remove the fuel tank and unplug each connector, & clean and inspect them. Upon reassembly, make sure the individual connectors are not pushing themselves out of their plastic holders. Carefully tighten any loose ones with needle nose pliers before re-connecting them. A small amount of dielectric grease or WD-40 applied to the electrical connections will help keep them corrosion free in the future.
Nov 05, 2009 | Honda VT 600 CD Shadow Motorcycles
The 2 screws on the top handle are loose. How do I get to them to tighten??
To tighten the screws on the handle, you have to take the top off. To do this, you have to take the black top piece off, and then you can reach the screw that holds the aluminum top. To remove the black top, use a small screwdriver to push the tabs that hold the top on. You can reach these tabs by opening the lid about half way, and going through a hole that is created by the hinge.
Oct 22, 2009 | Cuisinart WMR-CA Round Classic Waffle...
The sink faucet handle is hanging loose. i need to keep the handle in place and probably tighten a set screw.
If it is a Delta, there is an allen screw on the underside of the handle. If it another brand, there is a cap in the center of the handle that you can pry off and tighten. If the cartridge is loose and leaking, tighten the packing nut with a channel lock wrench.
Sep 07, 2009 | Plumbing
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fuel tank is loose
heyii if you can easily remove the seat then do it on your own or take your bike to the nearest mechanic and get your seat opened.. the end of tank is covered through seat and when the seat is opened you will be able to see a bolt(or may be two) and you can tighten them up. but also there is a little play provided by the manufacturing plant to resist shocks..,so keep this in mind while tightening the bolts.. Belated Merry X-mas and Happy New Year [:)]
Dec 27, 2008 | 2005 Honda VTX 1300 R
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Toto Drake ADA Compliant Toilet with Elongated Bowl Logo
375 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
