Question about Garden
When starting the engine, the engine turns until comression then stops. If I manually turn the engine back it does the same for several attempts and eventually starts.
  • 905 Answers
Your compression release is not working as it should. On some saws, the compression release is a manual lever / button that is pressed before starting attempts. Sometimes it is tied into the choke. Other saws have an automatic compression release, based on a centrifugal cam.
If you are able to rotate the engine through the compression cycle, then the release "lobe" is likley worn. If you are not able to rotate the engine through the compression cycle, then the release mechanism is jamming.
Posted on Sep 10, 2010
Have intermiate starting problem. Sometimes will start up and sometime cranks several attempts then will try and start then once finally starts after many attempts will chug for a few seconds then runs...
Sounds like you may have a fuel injector bleeding off when you shut it off, causing a flooding problem. If you can test the fuel pressure to see if it loses pressure after the engine is turned off that would help diagnose the problem. Depending on what vehicle it is, it could also be a bad fuel pressure regulator.
Feb 18, 2015 | Cars & Trucks
Fisher paykel excellence 6.5
take out plastic pump something may be caught in impeller water level sensors control power supply to pump
May 22, 2014 | Washing Machines
Engine won't turn over
More info is needed. Does the engine CRANK? In other words does the starter spin the engine over but not start? If it fails to crank, it is a starter or battery problem.
Feb 01, 2014 | 2004 Chrysler Sebring Convertible
Vehicle chugs and backs up after ignition turned off
It trys to go into reverse even if it is in park ?
Or is it a manual trans ?
Jul 06, 2013 | Ford Explorer Cars & Trucks
. i will turn the
Thanks for choosing FixYa and welcome.
Apr 30, 2011 | 1995 Chevrolet Monte Carlo
How i can check that my defrost timer in my fridge does not work
turn timer shaft by hand or screwdriver comresser will stop defrot elements will come on to defrost after 1/2 hr should hear motor start if it never starts timer is not advancing. replace.
Aug 17, 2010 | Whirlpool Refrigerators
Leaky power steering hose pressure side of the cooler area how hard is this to replace?
Sir,
There is no as such requirement of replaceing. You can use products like Magic ElFY to the leaking point better if use product "Magic" super glue it would help better then taking replacing expencise.
Oct 17, 2009 | 1994 Honda Accord
My 2000 Jimmy won't start, I can hear the fuel pump running and then shutting off before I attempt to start the engine. I also hear it running while I attemp to start the engine. The engine won't start...
The pump is working normally the reason it stops before you start the engine is it has built up enough preasure and cuts out. When you turn over the engine it starts up again as the preasure goes down when the carburator open's. The pump only helps the fuel from the tank. It seem's like dirt in your carburator. The reason it wont start after 3 minutes is the excess petrol in the carburator has evaporated hence need to pour more in. Check all pipes filters and carburator for dirt.
Aug 06, 2009 | 2000 GMC Jimmy
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
