Got a bizhub c550 and error code c-0206 came up and it just wont reboot or do anything. Help
  • 1,110 Answers
This code means that your paper tray 3 is not lifting the paper properly. Usually this is because the paper is not loaded properly. Open then close the front door to reset the code then immediately open tray 3. Check to insure that the paper is loaded properly. I would remove all the paper and then re-load. Leave tray 3 open long enough to verify that the machine will warm up and make copies. Then close tray 3 and see if the code comes back. If not then you are good to go. If it comes back then there is a tray lift problem with tray 3 and it will need service. Open tray 3 and reset the machine again. You can leave tray 3 slightly open to at least be able to use the machine until it gets repaired.
Good Luck and Thank You for using Fixya.
Posted on Sep 09, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Error code c-0206
Class c code. Means steering and suspension or chassis group. Abs light or stability control code. Will have to have 10 to 15000 scanner to read code. If I had access to all data for flow chart. Or call dealership to to see if it just means a level sensor or whatever simple. It will tell u what circuit of what sensor is affected. Trace wires. 95% of electrical issues are from abrasive movent or being smashed. Visible check wires
If abs sensor code, check for loose wheel bearings or hubs. Do this by jacking anfd properly supporting vehicle and push and pull on tire with alternating movements with one hand on top of tire and the other on the bottom. If any play, check if in ball joints as well. Top ball joint will show play a long time before bottom joint. Chevy independent front ball joints have special procedures to check. As u
May 15, 2014 | Konica Minolta Bizhub C550
Bizhub c550 loosing network access
does the copier have a static IP address or is dhcp meaning ever time the network is turned on the copier get a new/different ip address. Copiers love static so recommend your it person assign one.
Feb 11, 2014 | Konica Minolta Bizhub C550
two red light up doun, & do not printing...
Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Jan 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
427 people viewed this question
jasbo
jasbo
