Question about Dell 17" Monitor
The color on my Dell e772c CRT monitor goes off the greens and reds ( and all colors in general). The green are yellow and the reds are gray. It does this intermittently-it starts flickering then it goes off color. I found that when I pound the upper left side with my palm it pops back in. Any info on what the problem might be?. Thank you.
SOURCE: Monitor Flashes Colors when system powered down
Looks like the Burn-in mode is turned on. See here:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&message.id=70187
Cecil Thomas
Posted on Jan 14, 2008
Mark_Webber
  • 472 Answers
SOURCE: VERTICAL COLORED LINES ON MONITOR
Your panels are dying.
Well more to the point the driver tabs that run the panel are dying and are not going to be cheap to repair for either case.
For the stand alone LCD, it is cheaper to get another one.
For the laptop, find a laptop on Ebay or similar with a dead motherboard and swap out the screens, also gives you spare parts for the laptop. If you goto a repair shop and get a screen it will cost you as much as a new laptop.
Posted on Apr 08, 2008
MrsJGreen
  • 130 Answers
SOURCE: monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
Posted on May 31, 2008
SOURCE: power green light flash
there are bads solder in power suplly board in 2 transformer used in flyback lamp circuit.
paul@ula.ve
Posted on Jul 02, 2008
SOURCE: Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Posted on Feb 28, 2009
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
Apple M6494 CRT monitor. No color
1.Check the Signal cable.
2. Check the Green Drive Driver / output transistor.If they are used driver IC in stead of Transistor, check all supply voltage (56V to 85V)..
Sep 19, 2009 | Computers & Internet
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Weak red and green color of Sony GDM500PS
sounds like another IC has failed. there is one in this chassis (21N3) that causes similar problems. but i cannot recall what it is or it's IC designation, but i do beleive it is on A board
Jun 11, 2006 | Dell UltraScan P1110 21" CRT Monitor
Dell 17" Monitor Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
