Question about Gateway Computers & Internet
Our monitor goes black after the computer has been on a few hours and refuses to stay on, this is not the typical "at rest" mode. (5 years old fpd2185w)
    President:
  • 4,070 Answers
Hi! Looks like that the monitor is near to it's break point. 5 years of service is not bad. Mine just took 4years and have it replaced. The capacitors surely is faulty that it's better to purchase a new one since monitors nowadays got a lot to offer. HOpe this shed some light and thank you for using FixYa!
Posted on Sep 09, 2010
I tested in my PC with the cables of my own monitor (Benq FP92Wa) and the image pop-up just fine, but after 5 seconds the monitor goes black. I tried to reboot in safe mode but the same thing happens
If the monitor has the same problem on two different computers, it is most likely the monitor has a problem. This monitor is probably about 9 years old, and it would probably cost more to fix it than to buy a new one.
Jul 20, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Monitor stays on for 1 sec and goes black
sorenke, Monitor "switchmode-mode-power-supply" going into shutdown mode when detecting a FAULT CONDITION with some other circuit or with itself. Your monitor has same technology as any other backlit lcd display!! Read more of my responses to owners that have BLACK screen problems. Some have BLACK and BLANK screen problems Do you know flashlight test of SMPS status? How old is unit? How many Total "ON" hours unit have? Do you know what a bad electrolytic filter capacitor looks like? Have you been to YOUTUBE yet? 12fixlouie
Dec 15, 2009 | Hannstar I-Inc TW-191D Monitor
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
KDS 715S monitor is black and will not turn on
It might be a signal issue....try checking your 15 pin cable,
Apr 11, 2009 | Computers & Internet
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site out...@ www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor problem
You are experiencing an inverter board failure. You will need to replace or repair the inverter. The inverter drives the CCFL lamps that illuminate the screen if the lamps draw to much current or components on the board are overheating it will shut down the backlights. Some monitors have cold solder joints on the toroidal coils of the inverter that causes this problem, very typical with HP monitors, If you are handy with a solder iron you may try just re-soldering board and replacing push-pull transistors for a few more years of use. Provide make and model and I can be more specific about probable cause and solution.
Jan 18, 2008 | AOC LM729 17" LCD Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
