Question about Dishwashers
Samsung Dishwasher DMR78AHS fuse location and access
2 Suggested Answers
mjbr122
  • 4 Answers
SOURCE: How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Posted on Dec 19, 2014
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Whey does my samsung dishwasher smell?
We had a Samsung dishwasher for 4 years which I finally replaced with a GE. Always had a problem with a smell. I believe it's because Samsung dw's do not drain properly. I took the filter assembly apart several times (at the bottom of the unit) and cleaned it (was always full of greasy black gunk). This would help temporarily. I will never again buy a Samsung dishwasher (or refrigerator).
Jul 13, 2014 | Samsung DMR78AHS Builtin Dishwasher
Samsung dishwasher will not wash
This is usually caused by a bad case-break assembly, or a bad ECS sensor (if your dishwasher has one).
Jul 06, 2014 | Samsung DMR78AHS Builtin Dishwasher
Dropping door on a samsung dishwasher
You've got a broken rope link (the rope that connects the spring to the door, or it may have popped off the guiding pulley. If you can pull the dishwasher out about 6 inches, you should be able to see what is the matter and possibly fix it yourself.
Apr 22, 2014 | Samsung DMR78AHS Builtin Dishwasher
Why does the soap dispenser door does not open to release soap during wash?
I had this problem also with my Samsung Dishwasher if any large dishes were place on the end. It seems to stop the door from opening.
Apr 21, 2013 | Samsung DMR78AHS Builtin Dishwasher
Error code PE on Samsung dishwasher DMR78AHS
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
Aug 24, 2012 | Samsung DMR78AHS Builtin Dishwasher
The dishwasher does not clean glasses. They still have fingerprint and lip smudges.
Hi suzyb3,
Please look at my below Tip on how to ensure your dishwasher is working smoothly:
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Samsung DMR78AHS Builtin Dishwasher
DMR78AHS error code HE
Hi, the HE codes refer to temperature errors. The HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
Jun 13, 2011 | Samsung DMR78AHS Builtin Dishwasher
Heater stays on and melted all dishwasher safe plastic products. Only way to shut off is to pull the circuit breaker.
Sounds like the theromstat is shorted. Download the manual from Samsung before you try to replace.
Jun 01, 2011 | Samsung DMR78AHS Builtin Dishwasher
No power no lights samsung dmr78ahs
the electronic computer board is dead & needs to be replaced.
Jan 12, 2011 | Samsung DMR78AHS Builtin Dishwasher
Dishwashers Logo
414 people viewed this question
Top Dishwashers Experts
Owen Barnes
