Question about Kenmore 24032\24036 Top Load Washer
Washer won't agitate after filling up with water
    President:
  • 3,773 Answers
This involves the spin lid switch
Twist timer very fast a few times and stop it on spin with the lid closed. Wiggle the timer to get the points to connect. Even if you
just get a little bump then its the timer.
If none of this works then it is the timer plus maybe something else contributing.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 10, 2010
Whirlpool washer model ICWTW474OYQO Type 587-08
My I have a whirlpool washing machine Model # WED4850XQ0, Type 587-08, it fills up with water, but when it start to agitate, it starts to smoke.
Jun 19, 2013 | Washing Machines
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
