Question about GE DBXR463EDWW Electric Dryer
My dryer is about 8 years old and normally dries clothes in 30 minutes or less. In the past 3 -4 months, I turn the dryer on, setting it to his maximum timer level. It turns off around an hour and a half later and clothes are as damp as when I put them in from the washer. I have cleaned out the lint tray and even removed the hose in the back and blew the dryer vent that goes to the outside. Problem is still there. I have to restart my dryer 3 times now - all on full timer cycles - before my clothes are completely dry.
  • 101 Answers
Half of the heater coil bad
Posted on Sep 10, 2010
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
GE Front load Gas Dryer Model GTDP490GDOWS won't turn on
Remove the timer nob see if it is cracked, replace it with another nob or use pliers to turn the timer see if that works
Aug 26, 2014 | Dryers
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Even on "extra dry" on Cotton or Perm Press settings, clothes aren't anyplace near dry when the cycle decides it's done. I always clean the lint filter. I'm not putting in more than washes comfortably in...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 28, 2010 | Bosch Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | LG DLG5932W Gas Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
