Question about Ricoh GX3000sf InkJet Printer
My printer is in “alert” mode and will not print
  • 47 Answers
Remove the power cord, see if there is paper that is stuck in the print run, insert the power cable and restart
Posted on Sep 09, 2010
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
HP Printers
maybe an ic chips or an hp toner bias plate that contact the toner cartridge
Feb 19, 2013 | HP Office Equipment & Supplies
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
Printer is paused alert ribbon out, but we don't use a ribbon
Sounds like you're just in the wrong printing mode. Go into your front panel setup and search until you see
PRINT METHOD:
THERMAL TRANSFER.
Press the arrow buttons until it says DIRECT THERMAL, then save and exit.
Apr 05, 2010 | Zebra S4M Thermal Label Printer
My printers color ink cartrige has run out. I switched to printing w/ black only, but the printer still displays the alert and will not start printing. The model is a canon mx 300
All the Canon machines are that way, you won't be able to print unless you replace the color cartridge as well. There is not a way even in service mode to bypass this condition, they want you to buy more ink.
Feb 01, 2010 | Canon MX300 Office All-In-One Printer
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Jul 19, 2009 | HP LaserJet 1320 Printer
I'm using an Epson 1400 for dye sublimation and have installed a bag feed system. The 1400 is alerting that the cartrages are not the correct cartrages for this printer and will not let me print. Is there...
Hi I know if you go into Start, Control Panel, printers & Faxes, epson 1400, right click printing preferences, maintenance, speed & progress, and click on Disable Epson Status Monitor - this stops the printer 'thinking' the cartridges are running out... Joy
Jul 01, 2009 | Epson Office Equipment & Supplies
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Regards,
Fábio
Jan 13, 2009 | Zebra S4M Thermal Label Printer
Ricoh GX3000sf InkJet Printer Logo
52 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
