Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Fuel issues keeping edger working - Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Why do I have to keep the choke half way on to keep my 1818 case uni loader running
its a carb issue try to clean it then reduce the air fuel ratio thats going in the engine if you no nothing about tuning a carb be careful... you don't want to damage the engine
Aug 17, 2015 | Garden
Why does yard machine y25 string trimmer keep shutting off after a few minutes
Could be a coil issue and you'll need to check it as soon as it dies. If your have at least a 6mm module and a 4mm spark plug arc, then you have a fuel issue.
Oct 03, 2014 | Garden
Extreme challenge 26cc keeps chokeing out after a few mins then does it again
Fuel issue, carb adjustment, fuel lines and/or rebuild carb.
Sep 01, 2014 | Garden
Starts but won't keep going
Fuel issue, carb adjustment and or carb rebuild.
Mar 02, 2014 | Poulan Pe550 Gas Edger
Why is gas leaking from the air filter
This is a carb flooding issue, there will be a rubber tipped needle in the carb, if this is not seating properly fuel will leak through the air filter, you need to go into the carb, check the metering lever height and replace the needle, unfortunatly it is not possible to replace the needle seat so if it continues to leak after fitting a new needle it will be a replacment carb.
Jun 01, 2013 | Garden
I have a 128cd. The weedeater starts good but keeps stalling when switched to the full run position.
possibly a fuel starvation issue. check carb settings and possibly clean and replace diaphragms if needed.
Jan 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Won't start
Typically, this is a fuel delivery issue...but not always. Check condition of in-tank fuel filter, the fuel lines and inside the carb. Is the carb clean? If you want to clean it, remove the covers, gaskets and diaghrams (noting what went where) and spray liberally with non-flammable brake cleaner. Check the fine mesh screen in the fuel pump side of the carb. Clean it if needed. A rebuild for the carb may be due as they require this to keep operationg occasionally.
Aug 18, 2010 | Craftsman Garden
A relative has a weed eater featherlite 20c and thr primer bulb doesnt keep gas in it,is it supposed to?and if so what is the cause?And it want stay running unless u keep it running wide open.Why is that?
The machine is having a fuel delivery issue The purge/primer bulb PULLS fuel from the fuel tank, thru the carb and then to itself it pull any air/old fuel in the carb...and the PUSHES this mixture back to the fuel tank. There are check valves in carbs that have the bulb on them..Deteriorated fuel lines clog a screen in the carb and the ethanol in the gas works to deteriorate the fuel pump and metering diaghram in these carbs...You have to start at the tank with the fuel filter and go from there.
I'd say from the running symptons that a diaghram kit is needed for the carb...they are cheap and easily installed.
Aug 12, 2010 | Garden
I have replaced the fuel lines on flymore maxi trim 380
Sounds like a fuel delivery issue....pull and clean spark plug or replace it...remove and clean carb....check fuel filter, make sure its not clogged.
It may be time to rebuild the carb if cleaning it doesn't remedy this condition.l Rebuild kits aren't real expensive and sometimes fix this type of problem.
Jul 09, 2010 | Electric Garden
Engine is bogging down
Sounds like a fuel issue. Just enough gas getting there to start it, but not enough to keep it running. Start at thefuel line to the carburetor. Make sure fuel will come out at a sufficient stream. If it doesn't, work backwards towards the fuel tank, looking for clogged fuel lines and such. Clean whatever is suspect. If you get fuel all the way to the carburetor, you'll need to clean the carburetor. Careful disassembly is critical to getting it put back together correctly. Clean your parts with brake cleaner, not carburetor/choke cleaner, paying particular attention to orifices.
Best Regards, --WoobieDog--
Jul 10, 2009 | Garden
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
