Question about LG Ovens
The micro oven is not getting power on suddenly.The plug socket is o.k.
  • 11,896 Answers
Remove the cover. Some have screws, others have tabs to bend to remove cover. Look in the back next to power cord and power supply. There should be a fuse there. It may be blown and need to be replaced.
Posted on Sep 09, 2010
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Sep 09, 2016 | Kenmore Ovens
Is not working
The plug is either not getting power or is broken or dirty. Test to see which. Put meter leads from a multimeter into the socket and see if you get any voltage. Turn off the power to the stove and open the back panel and after turning power back on, carefully test again with the multimeter. If no power is coming to the socket, trace the wire to see if it is connected to a power source. If it is then change the socket.
Jan 24, 2013 | Ovens
Oven isnt working
I would make sure your plug wire has not come detached from its contacts and then take off the wall socket covering ( for goodness sakes kill the power to your kitchen) and check the wires connection there.
Apr 30, 2012 | KitchenAid Ovens
How do you know if your oven is hard wired in or plugged in if can't see it?
The wiring should go to a cooker switch box...usually found at the back of an adjacent cupboard or on the wall. This will usually have a large red switch with a power indicator light and a standard switched socket.
On most installations of seperate oven and hob...the hob will be hard wired to the big red switch and the oven will be plugged in to the standard socket. So switch the socket off and see wether your oven is off...if the oven is connected to the big red switch instead then it must be hardwired...
Feb 13, 2012 | Ovens
My Prestige PR1 S0 oven suddenly stopped working. I checked the socket it was plugged into. No power when other electrical item (radio) is plugged in. I plugged the oven into a gang socket which was...
It sounds as if the oven element short circuited and tripped the oven circuit. You will need to reset the oven circuit breaker or rewire the fuse at the switchboard.
If the oven indicator light comes on when you turn the oven on you will need to replace the faulty oven element.
Feb 23, 2011 | Ovens
Does the bush AE6BFS single fan oven require hardwiring or can it plug into normal socket
Generally speaking, a single oven can be used from a normal 13 amp socket.
If you are not sure, check the power used by the oven on the rating plate, as long as it does not exceed 3kw, then itt is o/k to use from socket.
If more than 3kw, then it will need to be hard wired.
Oct 25, 2010 | General Ovens
The oven model EOB 966X has turned off, no power
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, control board(main)l will be the culprit.
Nov 03, 2009 | Electrolux Ovens
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens Logo
56 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
