Question about Whirlpool Home
Jets won't turn on - Whirlpool Home
  • 11,896 Answers
Many of thee have the jets that you turn to activate and deactivate.
Posted on Sep 09, 2010
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
My Marquis Randezvous Spa won't heat
It's one of 2 things. If the jets turn on but no heat, you have a bad pressure sensor or temperature sensor. If the jets don't turn on you have a bad pump.
Apr 02, 2013 | Pool & Spa
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
My 1991 Kawasaki JS440 jet ski won't start and it
You might want to post this question in a different section. This is the computer games section.
Aug 23, 2012 | Video Game Consoles & Games
How to adjust the carburtor high and low on my weedeater head cutter?
Hi jamesbj44...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns to lightly bottom the adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know when you go to replace them.
Normally you adjust your idle jet to 1/2-3/4 turn open from the bottom seated position to start with...you re-adjust when the engine is warm turning the screw in or out till the engine runs smoothly.
The high speed jet is normally adjusted to 1 1/2- 1 3/4 open from the bottom seated positon, then re-adjusted to run smoothly when running at high speed by turning the screw in or out.
Free Answer...Please take time to rate me
Jun 06, 2011 | Garden
My talon line trimmer starts ok but after about 30 sec stalls. It starts ok again but the same stalls after 30 sec
you are not getting enough fuel. I have seen many small engines with this exact same symptom. You can take the little carburator apart, get a new diaphram, try to clean out the little channels with carb cleaner and they still won't get enought fuel. easy way to use this type is to use the choke in the half on or partly on to get more fuel into the motor. I have used this "choke on" type of fix on several units and it works o.k but can be a little tricky to get use to. Also you can try to clear the jets by carefully turn the running jet to the completely closed position. count how many turns it takes ( I usually count in half turns) to close the jet all the way (turn clockwise) then back out to original positon. caution never over tighten the jet. this could distort the brass and ruin the jet. Just take it down to closed then back it out and many times this will clear the jet. If this seems to work you may have to repeat this process from time to time to keep the jet cleared out. You can use this "jet clear" along with the "choke on" to get more fuel into the engine and keep the motor going good enough to make the trimmer work.
May 08, 2011 | Garden
It won"t start. Will not pull the fuel into the engine
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 19, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Home Logo
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
