Question about Autodesk AutoCAD 2010
HOW WE INSTALL AutoCAD 2011 ON WINDOW 7 - Autodesk AutoCAD 2010
How to install autocad 2011 step by step
Posted on Sep 11, 2010
Am installing autocad 2011 for the first time, after intallation thiss error msg came up. 'adi18res.dll not found'
Posted on Mar 15, 2011
3 Suggested Answers
DHINCE10
  • 169 Answers
SOURCE: Trying to install Roxio 2011
Please refer to the link below as it will help you fixing this issue, make sure to follow the steps carefully.
http://kb.roxio.com/search.aspx?URL=/content/000219CR&PARAMS=set-locale=en
Cheers . . .
Posted on Mar 09, 2011
SOURCE: when I install autocad2004 in
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
Autocad 2004 win7
pleas do not install any antivirus after the instalatio of window s 7 after installation of window 7pleas install all the softwere that you need to use and then install any antiviurs i hope all the softwere or programs work properly
Apr 08, 2014 | Autodesk AutoCAD 2004 for PC
I have i3 4gb memory, 1gb video, windws 7 64 bit.. but i cant install my auocad 2011
Are you trying to install the 32-bit version? I think you have to use the 64-bit version for 64-bit machines.
Sep 12, 2011 | Autodesk AutoCAD 2010
How to install autocad2004 on windows 7
On window 7-32bit, you can install AutoCAD 2004 normally, but AutoCAD 2004 is not supported on window 7-64bit
Aug 28, 2011 | Autodesk AutoCAD 2004 for PC
Step in stalling autocad 2011 in windows 7
You may use the link below for the pdf files for installation process of autocad on your computer.
http://docs.autodesk.com/ACD/2011/ENU/pdfs/acad_install.pdf
May 07, 2011 | Computers & Internet
My autocad 2011 is not opening . it says the application was unable to start correctly (oxc0150002) click ok to close the application . i use google chrome and desktop . Win 7 ultimate installed .
Try this first:
Uninstall and Reinstall the Visual C++ 2005 and 2008 redistributables. Restart the computer and try it again.
If that doesn't work:
Try using the repair option on the install software.
Uninstall autocad completely, restart the comp, reinstall autocad.
Also what version of 2011 do you have? Student Edition or just the regular one?
May 04, 2011 | Computers & Internet
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 on windows 7
Autocad 2004 is not compatible with Windows 7. Use a newer version.
System Requirements
For 32-Bit AutoCAD 2011 @
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=13784795
Aug 09, 2010 | Autodesk AutoCAD 2004 for PC
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2010  Logo
2,389 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
