Question about Microwave Ovens
Cannot unscrew light bulb cover in bosch oven tried wd40 , white vinegar and lemon juice but wont budge
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: removing light bulbs - HOW?
First of all, please be sure your oven is unplugged!
If the filament shorts, or if the bulbs are removed or installed without first unplugging the oven, it can cause damage to the controller board reuslitng in lights that don't work or that won't shut off.
But back to your bulb removal problem... They are often tacked in place with hot glue.
If you can heat it up a bit with a hair dryer, it may soften the glue enough that you can unscrew the base with a good pair of needle nose pliers.
It may be helpful to out the tips of the pliers inside the bulb socket, spread the handles apart, then turn while holding the handles out.
Tubular 40-watt bulbs (40T6 1/2 /2), available in supermarkets and hardware stores, may also be used for replacements.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
  • 248 Answers
SOURCE: I tried to change the surface light bulb in my GE
try using a oair of needle nose pliers.{be sure to unplug first} depending on position of light you may need a pair with 90 degree end.
Posted on Oct 07, 2010
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Operating interior light of bosch quantum speed microwave oven
Replacing the bulb is not really that tricky, and they only cost a few quid, so definitely worth doing:
1. unplug and take the cover off,
2. remove the two screws at the sides of the control panel, and move the panel out the way,
3. remove the metal plate covering the bulb area (5 screws),
4. squeeze and detach the springy fold of metal holding the bulb,
5. pull off the the bulb's electrical connections
6. unscrew and unhook the bulb, and replace!
My bulb was a 240V 25W T170 with right angled terminals.
Aug 18, 2013 | Microwave Ovens
Bosch microwave bulb
If there's no obvious cover or customer-accessible socket (and the owner's manual doesn't cover it), the manufacturer would prefer so.
It means that the whole outer cover or other panels would have to be removed to access the bulb or bulb assembly. In a bulb assembly, both the socket and bulb are replaced as one unit.
Jun 06, 2013 | Bosch HMT9626GB Microwave Oven
How do you change the light bulb in a JVM 1440?
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | GE JVM1440 Microwave Oven
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
May 02, 2011 | Microwave Ovens
How do I descale a russell hobbs slipstream iraon - I have looked on your site for free user manual and can not find it.
If you talking about descaling the built up calcium deposits in an iron, then there are many commercial products. You can find them in your grocery store, and reading the ingredients you may find mild phosphoric acid which is used in descaling large boilers.
But I prefer to use white vinegar (mild apple acid?) half and half mixture, poured into the iron and let heat for a few minutes and after cooled down dump the mixture out, repeat if necessary. When you refill the iron to use squeeze a little lemon juice in the water to make the iron goods smell lemony instead of vinegary, and the lemon juice is also acidic and will remove some of the scale.
Dec 31, 2010 | Microwave Ovens
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
Removing light bulbs - HOW?
May 24, 2008 | Hotpoint RVM1425 Microwave Oven
Light bulb replacement
Yes it just unscrews.  Unplug the microwave first!  Then use some needle nose pliers and put them inside the base open the pliers to put pressure on each side of the base.  Now turn the base counterclockwise.  Let me know how it turns out.
Oct 16, 2007 | GE JVM1651 Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
