Question about GE GSL25JFPBS Side by Side Refrigerator
I have a ge refrigerator model gsl25jfpabs. I have a water leak inside the wall of the freezer door. It only leaks when you depress the water dispenser. That tells me the line is leaking on the discharge side of the solenoid. Apparently the water runs down the line and leaks at the bottom of the door. Is there any way to access this water line so I can repair the leak. I pulled the door seal back but did not see any way to remove the molding on the inside of the door. I did get the face plate off of the front of the dispenser. My next obstacle is the dispenser control panel. How does this come off? Am I heading in the right direction?
  • 101 Answers
The door cant be opened its sealed with solid foam,i doubt its in the dispensor area the tubeing cant be replaced
Posted on Sep 10, 2010
  • Dan Braun Feb 11, 2013
    the tubing going to the water dispenser is broke off at the freezer door bottom wher it goes into the door can this be fixed and if not can i just disconnect the silonoid wiring so at least the ice maker still works
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE model gsl25jfpabs, freezer is cool like refrigorator, but won't freeze....
Look for frost on freezer back wall.
dirty condenser, condenser motor not running
bad compressor
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
GE refrigerator Leaks in back when trying to use water dispenser
That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
GE refrigerator, leaking water filter
The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
May 19, 2008 | Refrigerators
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
344 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
