Question about Ryobi Garden
I have a RLT30CESA and won,t start up check spark plug ok but cylinder head looked dry.
tripletauto
  • 1450 Answers
SOURCE: 2004 Rodeo Misfire on Cylinder 4
cylinder 4 is on the drivers side it is middle plug goes 2,4,6. it is possible for plug to go bad at mileage. look on the side of plug see if you can see a black mark on side this will be evidence of fire going down side of porcelain also look on plug wire for any trace of arcing. it is most likely a bad plug or wire on cyl 4
Posted on Oct 22, 2008
  • 5 Answers
SOURCE: 1996 ford tauras wont start
Sounds like a fuel problem. check fuel pressure and then check for power going to the pump.Verry likley needs a new fuel pump.
Posted on Dec 28, 2008
  • 491 Answers
SOURCE: 2000 3.2L V6 Rodeo
freeze plug
head gaskets
intake manifold gakets
these will cause problem
Posted on Jan 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: echo gt 2000 does not have spark and will not start
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Posted on Jun 21, 2009
  • 117 Answers
SOURCE: How to rethread spark plug hole in cylinder head?
First, go in corner and cry. Second, grab a good strong drink. okay ready to start....Cylinder head SHOULD come off. The reason behind this is that when you re-thread the hole, the fillings from the tap will go into you combustion chamber (BAD). Best place to go to get the tool would be your local auto parts store. they may have kits there that you can buy. If you don't want to take the head off. could try and sticking a vaccum beside it and hope that it gets most of the stuff
hope that helps, good luck
Posted on Jul 08, 2009
Won`t start
check for spark by pulling of the spark plug wire remove the spark plug and pull the engine over while holding the spark plug against the cylinder head
Sep 10, 2012 | Garden
1993 Ducati M900. On cold start up low power. Feels like dropped cylinder. After a few minutes returns to normal. My thoughts, one of the coils. Spark plugs appear ok.
if the plugs look ok and don't indicate a fuel mixture problem, it could be from a weak spark. You can check the resitance on your coil and plug wires with an ohm meter to see if they are within factory specs. Also, check for a possible vacuum leak around the carb & cylinder head on the cylinder that is missfiring. You can do this with some carb cleaner, spray it around the carb mount and vacuum lines---if the RPM's change it sucked some in. Hope this helps.
Jul 12, 2011 | 1993 Ducati Monster 900
Won't start after washing it, tries to turn over just won't start
check / remove the spark plug from cylinder head ,clean and dry them both,might water gets into it...
possible should adjust the spark plug tip allowance,make it slight closer.
or try to replace another spark plug. good luck..
hope it helps... please rate me if this is helpful...thanks
Jun 05, 2011 | Suzuki GSX-R 750 Motorcycles
Car overheated. Let cool down and topped up with antifreeze. Now car will not start.
check your oil for milky look you may have bad head gasket are crack hed from over heating wont start because water on spark plugs
Mar 01, 2011 | 2000 Chevrolet Cavalier
1963 allstate 125 scooter will run like new than it won,t start even thought it's getting spark and gas
Hi! I assume your problem only applies when the engine is hot. This could be one of several things:
1 - bad seals 2 - broken engine body (heat expands it and lets air in / compression out) 3 - related to above, but happening on top end (cylinder/head)
All these are hard to fix at home, but there it could also be related to a carb problem... imagine your scooter is running too rich, it will run ok for the first kms, but after you stop and because the plug is dirty and/or the engine is flooded, it wont start anymore.
When this happened did you check the sparkplug look (is it dark? dry or oily?)
Hope this helps! Regards
Feb 08, 2011 | Peg Perego Vespa Scooter
My vitara p reg 2L started smoking on start up, now it is misfiring any ideas where i start, I can't see any spark plugs in the engine-maybe i'm blind or stupid
Many new cars hide most of the engine underneath plastic covers that must be removed to find anything. The smoking problem may or may not be serious, but it's likely that the spark plugs will show black oily deposits on the interior insulators. Cleaning or replacing the plugs will usually make the engine run ok for awhile, but with continued smoking, it will foul the plugs again. If all the plugs are fouled, then look for something like a bad PCV valve that creates crankcase pressure when plugged. Worn out valve seals which allow oil to leak into the cylinders can account for smoking only on start-up. These seals can usually be replaced without pulling the cylinder head. Hope this helps!
May 21, 2010 | 1999 Suzuki Vitara
Husqvarna chainsaw stops when using it
Check for spark after it quits. If none, the ignition module may be dying when hot. If ok, check the muffler for plugging. Use compressed air to remove sawdust from cylinder and head area. If everything looks good, note whether the spark plug is getting wet with fuel after trying to restart the saw. If dry, check the fuel lines for cracking or other deterioration. Make sure the fuel tank vent is clear of debris. (Loosen the fuel cap for a moment, then see if it will start.) Hopefully, one of these suggestions will hit on the problem!
Feb 19, 2010 | Husqvarna Chain Saw 20" Bar
Hi,i`ve got a yamaha fz750 1988..and it won`t seem to run on all four cylinders..i took the air box off and while it was running put my hand over each carb one at once and found that on carb 4 it stopped...
Hi JIm,
If it stopped @ 4 tht means thts the only cylinder firing .
Remove the spark plugs,earth @ on the cylinder head, crank start and check for sparks...if its sparking tht means the coils etc. are ok.
As the spark plugs are out exam them to their conditions visit this site for more details :-
http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
From here you would know if its carburator or probably it may need a complete tune up....carburator cleaning, float level..adjustment, valve clearance.. new plugs (gap to specs.), check air filter, replace or fit 'inline' fuel filter thn balancing of the carbs.
Hope this helps!
Oct 29, 2009 | 1987 Yamaha FZ 750 MG (Europe-US)
Cl55amg
Check your spark plugs to make sure they are dry. If they're wet they'll extinguish the spark before it can make contact with the fuel, thus preventing starting. If your plugs are really wet, leave them out of the cylinder heads and use compressed air to dry the combustion chamber and plugs. If compressed air is not available, leave them open to air dry. Once everything is dry, reconnect your spark plugs and try to start again.
Jul 03, 2009 | 2005 Mercedes-Benz Mercedes Benz SL55 Amg
95 camry won`t start
Have the head gasket torqued to 60psi each bolt? if so, either the spark plug grooves got a crack, or the head is bent due to a past overheat... or overheats. If so, send the head to a machine shop and have it leveled out, and replace all gaskets replaced when putting back on. That includes, manifold, header, and head gaskets, as well as the oil seals and O-rings. Hope this will help you.
Aug 14, 2008 | 1995 Toyota Camry
Garden Logo
98 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
