Question about Maytag MDG308DAWW Gas Dryer
Dryer runs for 20 minutes then blows cool air, if you let sit for 5 minutes it will blow hot air again but only for a few minutes. I replaced the thermo fuse, and the hi-limit thermostat. I just had the cycle thermo test and it is fine. The exhaust shoot is clean and free of blockages. Don't know what else to do.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Heater not blowing hot air
Hi Chris, sounds like your thermostat may be worn and not closing all the way which would cause your engine to run cool at times. If you have a temp gage it should tell you if the engine is actually warming up or not. If not I would replace the thermostat.
Mar 18, 2014 | Ford Mustang Cars & Trucks
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
Jun 05, 2011 | 2002 Hyundai Santa Fe
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
A/C only blows cold for 20 minutes
Check the followings:
1. Pressure Switch connection - under front right hand side near lips.
2. Thermostat Switch connection - at the dryer under the hood
3. Retrun Valve maybe blocked - in the cooling pipe from the compressor
4. Cooling Thermostat in the compressor itself.
Jun 01, 2009 | 1997 Volvo 960
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Maytag MDG308DAWW Gas Dryer Logo
173 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
