Question about Thomson Lands Phones
Stopped showing pictures stays blank - Thomson Lands Phones
    Scholar:
  • 128 Answers
Try resetting your phone. Unplug from the power outlet and unhook the phone line, then if your phone have batteries remove the batteries wait after that wait for 10 - 15 minutes. Then put verything back in in reverse order. So the batteries goes in first the phone line and then plug the power cord to the power outlet. If this doesn't work try to check the warranty and call the manufacturer to have it replaced.
Posted on Sep 09, 2010
Why does video pictures on my lap top all go offafter 3 seconds
Does this happen on regular web pages or when running other apps like Word? I repair laptops and have found that sometimes the screen switch is flakey and needs contact cleaner to get it working properly again.
Oct 06, 2014 | Acer Aspire Computers & Internet
My screen wont show start up picture it stays blank it a net book NVA50
I am not a professional, but I have a lot of experience with laptops and pc's. Packard Bells are not good in the long run. They are cheaper which makes them appealing but so are their parts. Is it totally blank or do you see a task bar.
Apr 24, 2011 | Packard Bell Computers & Internet
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
My projection television will stay on for awhile and then the screen goes blank and the projector turns off, my satelite, my reciever, my surround sound all stays on. I am left with a blank screen with no...
When you mentioned blank does it have light on. If not check the filter for cloggging as the heat build up on the lamp can trigger a stop. Use a good forced cooling to confirm.
If the picture is clear and there is no illumination issues the bulb must be good and the issue may be power based.
If the main power supply can be cooled off , does the fault apppear, if so check the soldering of the power supply.
unless all this is confirmed the problem of the suspected bulb can stay.
Sep 19, 2010 | Televison & Video
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Pictures rotated will not stay and replay doesn't work
The frame will only show the pictures in the orientation in which they were loaded - you can change this in the frame, but it cannot save the changes. The only way to deal with it is to change the image orientation before downloading to the frame - this has to be done in image-processing software, and saved.
Mar 08, 2017 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Picture blinks on and off on my Trinitron Color TV, KV-35S36
My Trinitron Sony Television flashes off and on constantly and has horizontal lines.
Aug 31, 2008 | Televison & Video
I have a panassonic 50" plazma tv, when using it as a pc monitor the screen goes blank how do i stop this, many thanks, patsy
Does the screen go blank after the computer has been sitting unused for a while or is it immediately blank and does not show a picture. If it goes blank after a while, look in your power settings under control panel on your computer and set the monitor cut off to NEVER, also check your screen saver settings. If it does not show a picture at all check the user manual of your TV to see the supported computer resolutions and then check under display settings on your computer to see if the resolution that you are using is compatible. Hope this helps.
Apr 02, 2008 | Televison & Video
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Lands Phones Logo
80 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
