Question about Canon PowerShot S2 IS Digital Camera
The telephoto lens will not close - Canon PowerShot S2 IS Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
I am looking for a 14-200 lense for my lumix g1
You won't find one with that focal range as it's never been made. A lens with such a range will have far too many optical compromises and will be bulky and heavy, so it's unlikely to ever be made without a major change in materials technology. In 35mm terms, you're after an equivalent 28-400mm lens, and no manufacturer has ever come anywhere close to achieving that on any SLR system. In APS-C terms the equivalent would be an approximate 18-250mm which has been achieved by Tamron/Sigma, but the lens has to be used at modest apertures to achieve acceptable sharpness and exhibits very obvious barrel distortion at the wide angle end and pincushioning at the telephoto end. It's a lens which makes no sense at all as there are better performing digital bridge cameras which are smaller and lighter which can produce an overall similar image quality.
You can only achieve the focal angle you're after by using two micro four thirds zoom lenses or via two regular four thirds models with a four thirds to micro four thirds adaptor. Using micro four thirds models only, you could do this using the 14-45mm and 45-200mm lenses, both by Panasonic.
At the present time, the closest single micro four thirds lenses to what you want are the Olympus 14-150mm and the Panasonic 45-200mm. The first lens has a wide angle to medium telephoto capability, the second has a short telephoto to long telephoto capability.
I suggest that you click here to look at the micro four thirds joint catalog to see what's available.
Sorry you won't find precisely what you want, but I hope that my reply has saved you wasting further time in searching. Please take a moment to rate my answer.
Aug 20, 2010 | Panasonic Cameras
I have a vivitar telephoto lens for the camera, but not sure how to mount the lens. If I take the outer ring off, I dont know if the lens that came with the camera is suppose to also unscrew, or if there...
None of these Canon Powershot cameras have a lens which will remove.
The ring is only for a special kind of add on lens for either wide angle or telephoto, which will only fit this camera or possibly a few other models.
Never try to unscrew the lens, you will ruin the lens permanently.
Oct 17, 2009 | Canon PowerShot A540 Digital Camera
I want to use fairly telephoto lens in D3 slr nikon camera
You don't say what sort of telephoto you want to buy or how much money you want to spend but basically anything longer than a 50 mm is regarded as telephoto.
A staring point for you maybe the lens listed below: Nikon Telephoto Zoom 70-300mm f/4.5-5.6G IF-ED AF-S VR
It importantly has VR or "Vibration Reduction" on it to reduce camera blur when hand holding telephoto shots. This is just a staring point... You need to work out what you want to photograph Cheers Ian
Mar 17, 2009 | Nikon D40X Digital SLR Camera Digital...
Vivitar telephoto lense 500mm
Yes and no. If it doesn't come with one, you'll need a T-adapter for Nikon in order to mount the lens (you can get one from Vivitar, as well as from other manufacturers). The lens is not an autofocus lens, so obviously you will have to focus manually. It's also a mirror lens so it has a fixed aperture. It's what Nikon classifies as a non-CPU lens, so you cannot use the D90's exposure meter. You will have to shoot in Manual mode.
Feb 18, 2009 | Vivitar Telephoto 500mm f/8.0 Mirror...
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
May 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Telephoto lens
Hi, the adoptor tube are not compatible to the camera try to consult nearest lense seller they can recommend the exact adoptor lenses to your camera.
Sep 28, 2007 | Canon PowerShot Pro1 Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
