Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Drain in freezer keeps getting plugged up and bottom of freezer has big, frozen sheet of ice. Have had repairman out twice. I'd like to know if I could fix it myself. Yesterday, I took the freezer door off, slid food trays out, and chipped off ice, but couldn't find drain hole. Do I need to take the back off? The repairman melted the drain hole ice with a blow dryer and then sucked guck out with a turkey baster. I could do that too if I could find the drain! Thank you. Candace Miller
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
What causes ice build-up on the floor of the ice-maker/freezer compartment.
Hello, My name is Peter. I am a former Sears Home Services Tech.
You have a frozen/blocked drain at the back bottom of your freezer. This is a common problem that happens over time. I assume you have a side by side? I have found pieces of corn... The normal repair is to take the lower back freezer wall off, using hot water or a steamer defrost the drain hole, then install a hot wire from the defrost heater into the drain hole. That's if I were there.
Your cooling coil also has a heater. Every 8-10 hours your freezer will shut down for about 10 minutes to defrost. When it defrost the condensate (water) drips down to the drain. If the drain is frozen or plugged the water accumulates in the bottom of your freezer section. One water droplet will hang up in the drain and then another until the drain is frozen.
Here is what YOU DO. Using a hair dryer melt the ice on the bottom of your freezer. NO NOT USE A Hammer or anything like that. You will crack the liner and then have some serious problems.
Use a plastic spatula to help lift the sheets of ice out. Put the hair dryer toward the bottom back where the drain is located. Continue to melt this ice until you see the drain hole. Once found, pore warm water into the back tray. Try to collect this water and repeat the process until the water goes down the drain.
If you have any questions call me 443-306-1362. I will expect a Christmas card.
Oct 13, 2014 | Refrigerators
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
Sep 23, 2014 | LG LRBN22514ST Bottom Freezer Refrigerator
My bottom drawer freezer is accumulating a sheet of ice
Your defrost drain line is clogged or frozen so the defrosted water is leaking into the freezer compartment and freezing into a ice layer in the next cooling cycle. Get your defrost drain line unclogged.
Sep 16, 2014 | Whirlpool Refrigerators
Ice build up in bottom of freezer
somewhere in the back of most freezers there is a drain line. mine thought is yours must be plugged up. sometimes you can look in the back of the unit on the outside to see that hose. do what you can to try and clear it
Jul 05, 2017 | Refrigerators
My Frigidarie model #: FRS26ZGH is freezing water on the bottom of the freezer and leaking out onto the floor. I understand that the drain plug may be frozen. However, I do not see a drain plug or know...
The drain trough is at the bottom and way way back on the freezer side. After you get rid of the ice you need to get a flashlight and look way in back and at the very bottom of the freezer. You should be able to see the drain trough.It will be frozen, you need to get rid of the ice and then clean out the drain tube.A hair dryer might work to melt the ice but be very carful not to melt anything on the refrigereator.Then you can put hot water in the trough to be sure that the drain line is clear. Hope this helps.
May 19, 2011 | Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
There is a large sheet of ice accumulating on the bottom of the freezer. The ice maker is in the off .
Your defrost drain hole is frozen over. Turn the fridge off. Remove the lower bin. Take a hammer and carefully break the ice sheet to remove it. Use a hair dryer to defrost the drain line in the rear of the freezer just below the back panel. The drain line is up on the back inside the drain pan,not under the ice you will be breaking in the bottom.
Sep 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
109 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
