Question about Aiwa PX-E860 Turntable
How do i remove the stylus from aiwa px/e850 - Aiwa PX-E860 Turntable
    Champion:
  • Aiwa Expert
  • 271 Answers
Hi, grip it at the front edge and pull downward then forward. styluscity@gmail.com
Posted on Sep 13, 2010
If I put a external preamp on a aiwa px-e850, bypassing the built in preamp, will it upgrade the sound?
Hi, I doubt if you would notice any improved sound, the speakers (in my opinion) make the most difference.
Jul 08, 2016 | Aiwa Audio Players & Recorders
If motor on aiwa px e850 turntable only turns intermittantly, has the motor worn out?
It might have. But the thing to do is to spray the bearings or the motor with Servisol Cleaning fluid. It could be just muck that's got inside it. A drop of oil might even help.
Aug 18, 2014 | Audio Players & Recorders
How do I remove the stylus of an Aiwa PX-E850 Turntable?
Hi, grip the stylus between thumb and forefinger. Then in a pulling down and forward motion remove stylus. Cheers john. Stylus City
Apr 02, 2014 | Aiwa PX-E860 Turntable
My stylus for my aiwa px-e850 is loose. Can it be tightened?
I don't think so. If it's fitted correctly it should not come loose. It sounds like you need a new cartridge. Sadly they do break. But if you get the same type you will have a spare stylus.
Jun 15, 2013 | Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
On my Aiwa PX-E860 the automatic mechanism is failing - when i thry to manually place the stylus the platter does not turn - is there a way to by pass the automatic part and just have it manual?
Select the record speed.
Press the 2 down arrows or triangles( placed side by side) - This the same thing you press if you want the styles to lift during play
Place the stylus on the desired spot.
Press the same button again.
The stylus will drop to the desired spot & continue playing
If you have the manual look it up, else download one from this site after becoming a member(its free)
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Nov 30, 2010 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Nov 05, 2009 | Aiwa PX-E860 Turntable
I need a spare turntable belt for a Aiwa PX-E850 turntable. What size is needed?
I did it by searching the internet rather than being led into a a system which costs money.
JMB
Aug 02, 2008 | Aiwa Audio Players & Recorders
Aiwa PX-E860 Turntable Logo
1,627 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
