Question about Acer AL1916W 19" LCD Monitor
The display is not fit on the monitor help me how to fix it thanks!!! ayanblink@yahoo.com
  • 11,361 Answers
You need to set your PC video resolution to the native resolution of this monitor, which is 1440x900 @60Hz. Mkae sure to to have correct video card driver installed and may also need the driver for this monitor if the native resolution is not listed.
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 09, 2010
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
My yahoo messenger cannot display the message that i type..
there might be some problem with the messenger. Its better to reinstall it . It will work fine after that. Download yahoo messenger here--> http://in.messenger.yahoo.com/download/
Thanks for rating Good luck
Mar 13, 2011 | IM Monitor Software Yahoo Messenger...
VDO Dayton 5,8'' Monitor MM5000 The display is broken- u can see only 1/3 of the screen. Can it be fixed?
By bogdan_nita1 on Oct 18, 2009 " " VDO Dayton 5,8'' Monitor MM5000
The display is broken- u can see only 1/3 of the screen Salutare ! Este monitor complet de vanzare . 150 euro . Relatii pe mess : spintilie@yahoo.com
Oct 18, 2009 | VDO Dayton MS5000 GPS Receiver
Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 29, 2009 | Samsung SyncMaster 244T 24" LCD Monitor
Problems getting the native resolution
There are drivers for this. Only Vista ones though. Get them off the website, they sort loads of issues out
Nov 09, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Blue color is all I get on monitor
Hi!!
try to set the
display setting on your desktop
here your gonna do
1.go to the control panel
2.go to the display settings
3.and then settings
4.advanced
5.try go the brand of your video card
6.then set the color to default
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Blurry tv monitor
try to adj picture settings.
Aug 02, 2008 | Televison & Video
Wiring problem I NEED HELP!!!!
You can fix it yourself.
atdlee@netzero.com
Feb 25, 2008 | Car Audio & Video
Monitor is black, power light is blinking
From your description, it sounds like a failure in the internal power supply of the monitor. Having the unit repaired is an option, but the cost is likely to be prohibitive, around $95.00. I would recommend that you upgrade to a newer display, and you should be able to do so for less than $200.00. Again, from the description, the monitor is where the issue is. I would recommend taking your display to some other computer and confirming that the issue follows the monitor and not the cables or PC.
I hope this helps with your issue.
Brad
DigitalBrainz, Inc.
Oct 24, 2007 | Dell Computers & Internet
Dull display
I have lg studioworks 57M monitor. The main Problem was No Display, No Power Light.What was the Problem? Can give the technical solutions? just email as ed_1455@yahoo.com.ph
Oct 28, 2006 | LG Studioworks 57M Monitor
Acer AL1916W 19" LCD Monitor Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
