Question about Maytag Neptune MAH5500B Front Load Washer
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 10, 2010
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Apr 26, 2009 | Kenmore Washing Machines
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
