Question about Dryers
Dryer runs but will not get hot, what is the most common reason or part that should be replaced?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Will not run breaker and fuses are hot current
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 16, 2011 | Roper REX4634KQ Electric Dryer
Dryer will not start, removed front panel and timer motor very hot. do I need to replace timer motor?
heatman101
Jul 03, 2011 | Maytag PYE2200 Dryer
My dryer wont turn on but the inside does get hot what could be the problem
if the inside is getting hot, by not turning on I'm guessing you mean not spinning, you need to check the belt if this is the case, also, be sure the door safety switch is working, you can check that by simply jumping the 2 wires together, if it runs then, replace that switch, but I would check the belt first if you need any help with that feel free to reply
Jun 24, 2011 | Dryers
Kenmore electric dryer was running very hot now won't start at all
heatman101
Mar 21, 2011 | Kenmore 62722 Electric Dryer
Will not start when hot buzzing noise
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Frigidaire Dryers
Timer runs dryer gets hot but drum does not come on to spin clothes
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 13, 2010 | Crosley CDE6000 Electric Dryer
Dryer quits rotating after it runs for a while.I just replaced the belt same result.
Hi, The motor is getting hot and kicking the overload off... you will need to replace the motor...
heatman101
Sep 15, 2010 | Kenmore 63942 Dryer
My Kenmore dryer runs for for ten minutes then shuts off. It also pops the circuit breaker. The drawer runs fine and then just turns off. Heats up. Lint is all clear, but don't know why it shuts off?
Either the motor gets hot and blows the breaker or if it is electric the heater element gets hot and then shorts out...
heatman101
Sep 09, 2010 | Kenmore Dryers
Dryer got hot but stop running dose not get dry
heatman101
Sep 06, 2010 | Frigidaire Dryers
My dryer keeps running really hot and blowing the heat sensor. I have had a tec replace this part 3 times and he just replaced the board. stopped working after one load. makes a clicking noice when I hit...
heatman101
Aug 24, 2010 | Whirlpool WED5900S Electric Dryer
Dryers Logo
Top Dryers Experts
