Question about Amana AFD2535DES French Door Refrigerator
Humming sound about every 3 minutes for the last few weeks. Today the temperature is 30dg. in freezer and 39 in refrig section. This refrig was bought in June, 2005 and after 1-1/2 year had to have the evap (fan) replaced could this be the same problem. I'm hearing that Amana is a very bad appliance. Is it wise to repair or replace it. Thanks Jacquie
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
I woke up the other day to find my fridge warm and everything in the freezer defrosted. The light comes on when I open the door and what sounds like a compressor starts up every few minutes but seems to...
What you are hearing is most likely your compressor cycling on the overload due to drawing excessive amperage, You will have to have it checked out by a tech
Jun 26, 2011 | Refrigerators
Bottom freezer seem to be fine top refrig.is warm?
couple things to start off with is make sure the fan from freezer section is still blowing...may have to with door open hold down door switch as they sometimes stop running when you open door...if the fan is still running,then is the back wall of freezer frosted up you could have a defrost problem a defrost thermostat, or a heater issue... last make sure you have a clear passage from the freezer to the refrig such as the airflow gap or damper assembly which will be either a manually damper or a automatic damper//this is the flap that opens and closes usually by temperature to let air from freezer to refrigerator side....also make sure the unit all together is running properly the freezer is the last part to give you a problem as this is where the coolant actually starts then is pushed into refrigerator....few things for you to check repost if you have anymore questions....good luck
Jan 05, 2011 | Amana ARB2217CSR Bottom Freezer...
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Temperature of Refrig and Freezer too warm
Sounds like your fridge may be short of refrigerant.
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Amana AFD2535DES French Door Refrigerator Logo
69 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
