Question about ASUS DRW 24B1ST Disk drive DVD RW ( R DL) DVDRAM 24x24x12x Serial ATA internal 525" Burner
Oh yes, the optical disk since I put the two newer ones in has not been designated a drive letter yet. It does not appear with the Start/Computer/ path and only device manager knows it is there. Along with Windows 7 Home Premium, I put an Intel Core2 Quad CPU Q9400 @ 2.66 GHz, onto a EP43-UD3L Gigabyte MB, 4.00 GB RAM, Nvidia Geforce 9800 GT, with 830GB free on hard disk. Also use an external harddisk in F I use for back up through a USB connection and a 650 watt power supply. All of the USB ports seem to work fine even with the ‘non accurate” (my words) USB drivers. All the internal disks, fixed or removable storage, use the SATA links. By the way, there is no Audio out connection on either one of the two most recent optical disk devices to hook into the MB as was the case for the IDE ribbon devices. Sorry about the length and obtuse nature of my question. I have been at this since the first of last weekend and have gotten not where. almost finished
  • 17 Answers
SOURCE: ASUS DVD RW model DRW-1814BL
try reinstalling your operating system ( try format your cd or just repair it). The system will automatically detect the driver for your drive but if it was not listed in the bios try checking the cables attached to your drive.. or still if not.. the drive may be damaged.
Posted on Jan 23, 2008
SOURCE: DRW-1814BLT compatibility with IDE hard drive
With A8M-VM series Mother Board the Asus DVD Writer Model No.DRW-1814BLT Lightscribe Not supporting.
Posted on Feb 04, 2008
adnanbhatti
  • 1188 Answers
SOURCE: I am having difficulty with my ASUS SDRW-08D1S-U
In the device manager, right-click on this device and select "uninstall". Physically remove the device from the laptop and restart your system, the driver will be loaded again upon restart.
The above should solve your problem. You should also download and install latest BIOS and drivers. You can find them here.
Posted on Dec 16, 2009
Davethesnake
  • 689 Answers
SOURCE: I have an asus eeepc and I have just purchased a
only certain models auto-cofigure,refer to manufacturers site/book to find out which one to buy with the least hassel and guaranteed configuration
Posted on Sep 04, 2010
bayyagg
  • 1672 Answers
SOURCE: hi i my computer suddenly
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Posted on Nov 07, 2010
I have a sony vaio VGC-LN1M, I insert a disk in to drive sd/mmc [d:] it then still asks me to insert a disk .
it usually means that the sd/mmc card is not formatted with a file system recognised by windows, or is not formatted at all, or is faulty. however, sd/mmc is not a disk, so it sounds like either you are confused, or your optical drive is using the same drive letter as the mmc or sd port. If that is so, right-click on my computer, go to manage computer - then disk management. select the optical drive right click and select change drive letter and paths. now pick an un-used drive letter for the optical drive and apply the change. you may need to restart the computer. then the optical drive should work.
You haven't specified what version of windows you are using, but the action is roughly the same.
Aug 15, 2014 | Computers & Internet
Tip
Disk Drive Shows Up In Device Manager But Not My Computer
When you install a disk drive, Windows installs the disk drive's drivers and assigns the disk drive a Drive Letter. When your disk drive shows up in the Device Manager, but is nowhere to be found in My Computer, this means the drivers installed, but Windows didn't assign the disk drive a Drive Letter. The following procedure will help you to assign your disk drive a Drive Letter in Windows XP, Vista & 7. Note: You cannot modify the drive letter of your main partition on your PC.
Windows XP
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance. Note: If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
  8. You can now close any open Computer Management, Administrative Tools, or Control Panel windows.
Windows Vista
  1. Click on the Start button and then choose Control Panel.
  2. Click on the System and Maintenance link. Note: If you're viewing the Classic View of Control Panel, you won't see this link. Just double-click on the Administrative Tools icon and skip to Step 4.
  3. In the System and Maintenance window, click on the Administrative Tools heading located near the bottom of the window.
  4. In the Administrative Tools window, double-click on the Computer Management icon.
  5. When Computer Management opens, click on Disk Management on the left. Disk Management should appear on the right side of the Computer Management window after just a few seconds of loading. Note: If you don't see Disk Management listed, you may need to click on the '> icon to the left of Storage.
  6. On the right-hand side of the screen, locate and right-click on the drive that you wish to change the drive letter of and choose Change Drive Letter and Paths.
  7. In the Change Drive Letter and Paths window, click on the Change... button.
  8. The Change Drive Letter or Path dialog box will appear. Choose the drive letter you wish to assign to this partition. Click OK.
  9. The Confirm window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?" Note: If you have software installed to this drive, the software may stop functioning after a drive letter change. Nearly all software defaults to the primary drive though, so this is rarely a concern.
  10. If you're sure you want to make this change, click Yes.
  11. You can now close any open Computer Management, Administrative Tools, or Control Panel windows.
Windows 7
  2. Click on the System and Security link. Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link so just click on the Administrative Tools icon and skip to Step 4.
  3. In the System and Security window, click on the Administrative Tools heading located near the bottom of the window.
  5. When Computer Management opens, click on Disk Management on the left side of the window, located under Storage. After a brief loading period, Disk Management should now appear on the right side of the Computer Management window. Note: If you don't see Disk Management listed, you may need to click on the '> icon to the left of the Storage icon.
  7. In the Change Drive Letter and Paths window, click on the Change... button. The Change Drive Letter or Path dialog box will appear.
  8. Choose the drive letter you wish to assign to this drive by clicking the letter from the drop-down box on the right. Click OK.
  9. The Disk Management window that appears advises you that "Some programs that rely on drive letters might not run correctly. Do you want to continue?" Note: If you have software installed to this drive, the software may stop functioning after a drive letter change. Nearly all software defaults to the primary drive though, so this is rarely a concern.
on Feb 16, 2011 | Computers & Internet
Pendrive install ridata
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt.
To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter.
Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive.
In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter.
As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
Oct 03, 2013 | Computers & Internet
My toshiba external hard drive won't be opened
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Jan 14, 2013 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Where do I go on my computer to open the optical drive. I am new on the computer and need simple instructions. HELP!
For Windows XP:
Click on Start > Double-click on My Computer > Double-click on the drive letter which corresponds with the optical drive. Most of the time it is the D: drive, or E: drive.
(A: is generally for a Floppy Disk drive
No B:
C: is for the Harddrive )
For Vista and Win7:
Click on the Windows logo button > Double-click on Computer > Double-click on the drive letter that corresponds with the optical drive.
Regards,
joecoolvette
Jul 02, 2011 | Computers & Internet
Hp(cefc-4gp pendrive)get fault.the fault is when i insert my pendrive (removable disk drive appears).when i open it .it will not open.my system get hanged
You can try formating the drive first (as long as you don't have anything on it). If they doesn't work, try giving it a new drive letter. It could just be a conflict.
How to change a drive letter loadTOCNode(2, 'summary'); To change an existing drive letter on a drive, on a partition, or on a volume, follow these steps:
  5. Click Change.
  6. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK.
  7. Click Yes when you are prompted to confirm the drive letter change.
The drive letter of the drive, the partition, or the volume that you specified is changed, and the new drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool.
Mar 07, 2011 | Microtoolz PenDrive Autorun
How do I change drive letter for e to c on my local drive
How to change a drive letterTo change an existing drive letter on a drive, on a partition, or on a volume, follow these steps:
  3. Click Administrative Tools, double-click Computer Management, and then clickDisk Management in the left pane.
  5. Click Change.
Dec 09, 2010 | Computers & Internet
I need to reinstall ethernet driver on my desktop but it will not connect to the internet.
If this problem is in direct relation to the heading,
Dell Dimension E510 Desktop PC, here is the download page for the Ethernet driver,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIMENSION%205150/E510&os=WW1&osl=en&catid=&impid=
Download to the computer you are on now, if it has a CD burner optical drive.
Burn this driver to a blank CD-R disk.
(I advise do not use a CD-R/W disk, because it can be written over. Do not put anything else on this disk but driver/s. Label the center of the disk)
Now start the Dell, wait for Windows to fully load, put this disk in the optical drive.
Left-click on Start>My Computer.
Go to to the drive letter that corresponds with the optical drive the CD disk is in, and Double-click on the drive letter.
Follow the Installation Wizard's instructions.
Jan 04, 2010 | Dell Dimension™ E510 PC Desktop
My hard drive wouldn't boot one morning. I bought a new one and like a dork, I loaded it while the bad one was still connected and Windows designated it as a ''J'' drive. Windows wouldn't allow me to...
You need to right click on "my computer" and click on manage
Highlight disk management
Right click on the disk and click "change drive letter" Hope this helps.
Oct 22, 2009 | Computers & Internet
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
ASUS DRW 24B1ST  Disk drive  DVD RW ( R DL)  DVDRAM  24x24x12x  Serial ATA  internal  525"  Burner Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
