Question about Acer Aspire One Netbook 8.9" Notebook
My acer aspire one doesn't turn on. the power button flickers twice but doesnt actually turn on. is there a way to turn it on? i want to send it off but i would like to get my photo's off it and onto my phone. is this possible even when my computer is dead?
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
Wireless Button (Acer Aspire 3630) Doesn't Work
Press Fn and the wireless key at the same time. That should toggle your wireless on and off.
Jul 10, 2012 | Acer Aspire One PC Notebook
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
The power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
Jul 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire one. 3days old. flickering
Ok if its brandnew and within warranty contact the seller. This should not be happening, to early to give you problem like this.
Apr 24, 2009 | Acer Aspire One A150-1006 Notebook
Acer aspire 3003lc no power
What you're describing is a problem with the Memory Module or FSB. Unfortunately, the only way is to get it tested by a qualified engineer and replaced.
Is it still under Acer warranty (usually 12 months)? If so, contact them and they'll repair it, if not, I can only suggest you shop around for a respectable, but cheaper engineer.
Sorry I can't be of more help.
Dec 03, 2008 | Acer Aspire 3000 Notebook
Function F6 works only sometimes to blackout screen on acer aspire 5315
I just came here looking for a solution to the same problem. I have an Aspire 1800 which has a front panel of buttons for the Arcade mode. Basically i just wiped all the buttons again resonably vigiously as i was pissed off and low and behold the FnF6 works again. I tried this after i read another artical suggesting the removal of the touchpad driver. so obviously something is still depressed much like a sticky key which basically switches the screen immediatly back on as i had a flicker at least when i did FnF6. Hope this helps..
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
Bluetooth
If you have a bluetooth button at the front it doesnt mean its inbuilt, most Acer laptops don't have it although the button is there.
assuming you have set up the bluetooth correctly
Your model does list it has inbuilt but, if it is the light should flicker, you should also check the latest driver
http://support.acer-euro.com/drivers/notebook/as_5100.html
Aug 28, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
