SOURCE: How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
SOURCE: how to change the ip
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
