Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont turn on, check power supply no result
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
Microwave turntable wont turn
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
Oct 30, 2012 | Frigidaire FMV157GM Microwave Oven
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
My bosch innowave stops after like 30 seconds...power just cuts off and food doesnt get warm
Hi There,
Unplug your microwave for ten minutes, plug it back in, and test it on a cup of water. If the problem persists, you'll have to take it in for servicing or buy a new microwave. I don't recommend continuing use if it's turning off on it's own, that usually means a bad power supply and can result in curcuit damage.
Jun 06, 2012 | Bosch Microwave Ovens
Indesit cooker clicking
Hello, the clicking sound is as a result of bulged capacitor. One or more capacitors on the power supply board inside the unit is bulged, that's why you are hearing the clicking sound. Have the power supply board check and the cause of the porblem will be revealed. Good luck.
Dec 29, 2011 | KitchenAid Microwave Ovens
Emerson mw9113ss wont turn on
If the is no power to the microware and the display does not showing any signs of power then you internal fuse has been damaged. First I would suggest you move the mocroware to a different outlet to eliminate the outlet as the problem. Once you have eliminate the outlet, then disconnect the power and then remove the covers and find and replace the fuse. Let me know the results
Nov 27, 2011 | Emerson Microwave Ovens
No power... No lights or Fan. The 110 outlet has power. I tested it. The display is blank. I have unplugged the microwave but I had the same results. Is there a fuse in the microwave?
Most microwave ovens do have a line fuse. I can't be completely sure if your does, since you did not supply a model number. If the cover is removed, the fuse should be close to the power cord. Hope this helps you.
Mar 13, 2011 | Whirlpool Microwave Ovens
Smell like burning rubber coming from microwave sound like its running harder all of a sudden what could this be unit is 9 years old kenmore gallary microwave
Possible that the fittings along the magnetron had come to some dampness that has resulted in the heating of the mountings that causes the burning of the mounting gaskets.
If will be best to remove the magnetron and refit it after cleaning it dry and making sure there are no food particles lodged inside that can cause this out of turn heating to happen.
please check also on the main capacitors and the power supply for any heating.
Cleaning the entire unit after swittching off power , cleaning the PCB and the contact leads must solve the issue. If there are any loose joints tighten them.
Nov 15, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
Our Sharp R937 Microwave is playing up. It is
oh dear, its just about to pack up on you, the power supply is on its last legs,, my addvice is dump it and buy a new one, fixing it will cost you both arm's
dont go trying to fix it yourself,, if you go inside of this unit and tuch the wrong bit it could very well kill you stone dead, there may well still be over 1000' volts flying about inside of it,,, volts kill you!!!!!
play it safe,, buy a new one!
Oct 21, 2009 | Microwave Ovens
Small fire n microwave
check mains supply at control circuit, and check all the high voltage circuit diode and condencers and magnetron.
Dec 20, 2007 | Whirlpool MH7140XF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
