Question about Troy Garden
How to level the deck on a troy bilt bronco rider
  • 376 Answers
SOURCE: I need a diagram to adjust/level the Deck
The adjustment is on the left rear deck hanger. Loosen the 1/2 lock bolt in the center of the large nut, then turn the large nut with a adjustable wrench or socket, if you have one that big, clockwise or counterclockwise to raise or lower that side to equal the right side height.
Posted on Jun 05, 2009
  • 582 Answers
SOURCE: How do I level the mower deck? I have a 48
the easyest way i have found is to use 4 pieces of brick , get the mower on a level surface place one oiece of brick under each corner of the deck and make adjustments until the deck starts to raise off the bricks
this should be the three inch level . my mower had the same problem and this worked for me
Posted on Sep 03, 2009
SOURCE: My troy bilt super bronco started up fine, turned
Have you checked the fuse on the starter?
Posted on Apr 20, 2010
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
Need diagram to replace tension spring for drive belt
Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
Nov 03, 2015 | Garden
Troy bilt 26J Mini Rider clutch sticks. How do I adjust the tension?
the pully midway from engine to deck. Look for an adjustment where the pulley articulates with the foot control. The pulley probably moves to provide adjustment control
Sep 28, 2015 | Troy Garden
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
I recently purchased a Troy Bilt Bronco riding mower from a local Lowe's Store. It was delivered by a flat bed truck. The mower was removed by placing the forks of a fork truck under the mower deck and...
I never heard this problem before.
It would seem to me that if you were to lift a mower with forks, they should NOT be under the deck.
I have a Craftsman and I think my deck is bent, I can't align it in all the directions the way I should be able, maybe they did that to mine.
I would call Troy Bilt; it's important enough.
Gary
May 31, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
615 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
