Question about ASUS DRW 24B1ST Disk drive DVD RW ( R DL) DVDRAM 24x24x12x Serial ATA internal 525" Burner
Trying to install a new ASUS DRW 24B1ST CD\DVD player purchased as an OEM device at Frys - it will not install. Device Manager says "A driver (service) for this device has been disabled. An alternate driver may be providing this information, (Code 32).” The driver listed in the Device Manager that is listed as disabled I believe is the correct one coming with a new Windows 7 Home Premium install, and is found at C:\Windows\system32\-DRIVERS\cdrom.sys. There was another cdrom driver previously installed when I installed Windows 7 Home Premium and used the start up disk to load some CyberLink software for that CD/DVD/Blu-ray r/w (blu-ray reader only) player on 1/10 for a ? brand OEM blu ray reader that I only used for cd and dvd read/write, not needing the blu laser yet. It quit working claiming I believe the same thing by Device Manager, but don't have that info now. I deleted that driver, found at above C:\…DRIVERS\CLBStor.sys the other day thinking it might be causing problems. The blu ray is sitting in my machine, but not connected to the board or power supply. Both use ATA connectors. -> more to follow
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Installed DVD BRN ASUS/DRW-24B1ST.
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps don
Posted on Mar 14, 2011
CaptainHawk1
  • 345 Answers
SOURCE: WINDOWS SEVEN all of
Try each of these in this order:
  1. Attempt to update the drivers/firmware. A Windows update may have had a compatibility issue. Right Click Computer -> Manage -> Sytem Tools -> Device Manager -> Click the "+" icon onCD/DVD Drives, choose the drive, Right-Click on it -> Update Drivers. If Windows is unable to find an updated driver or firmware go here.
  2. If the Windows isn't seeing them, that means data has become corrupted and they aren't there. These are Plug-N-Play devices so the basic drivers should show up automatically if the device itself can be seen. When you say that it can't see the drivers are you really meaning that it can't see the devices?
  3. Uninstall the drivers if they are there (again, if they are there, Windows is seeing them). Right Click Computer -> Manage -> Sytem Tools -> Device Manager -> Click the "+" icon on CD/DVD Drives, choose the drive, Right-lick on it -> Uninstall. Repeat for the second drive and for wherever the "crosslink" is located. Then go to step 4...
  4. Power off you PC. Disconnect the power cable from the PC. Open up you computer case, make sure to use latex or neoprene gloves to avoid accidental static discharge. Disconnect both the SATA data cable and the SATA power supply cable from each device. Reconnect the main power cable to to the PC itself. Plug the PC back in turn it on. Ignore any messages about devices being missing if there are any. Wait for the computer to boot completely and shut it down again. When it is completely powered off, again disconnect the main power cable to the PC. Reconnect the SATA data and SATA power supply cables. Close up the PC. Reconnect the main power cable to the PC and turn it on.
  5. Upon booting up, Windows should automatically detect all new devices and automatically install the generic drivers. When it's done doing that and it tells you that the devices are ready for use, go back to step one and an update the firmware directly from the ASUS link I provided.
Posted on Jun 23, 2011
How to install a ASUS burner
In a PC, simply open a drive space on the computer, insert the drive by sliding it into the slot and screw it in place. On the rear of the burner are two connections. One is for the Power attachment and the smaller one is attached to motherboard.
That's it.
Oct 29, 2013 | OEM Systems Asus Drw-24b1st Dvd / Cd...
DRW-24B5ST dvd writer is not detected by WIN7, it can been from BIOS and from device manager of windows, but not from My computer. Laso opening of hatch doesnt work from hw buttoin or from SW. Mother board...
Hi folks , i had same problem and i solved with last driver
http://www.gearsoftware.com/support/drivers.php
Just install and your driver will work
WORKS !
Jun 13, 2012 | ASUS Computers & Internet
File corrupted or missing ccode 39
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? ! or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in
this should activate found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 15, 2012 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19).
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Nov 03, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Installed DVD BRN ASUS/DRW-24B1ST. Says there is a Code 19 problem--something about in the registry--doesn't work. Same situation before installing this new hardware.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 14, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
When trying to install driver get error " DVD Asus
I found Asus driver in the site portal.I also guess that if your PC is an OEM and you just replace the DVD.Also is a good idea to update the firmware.Here is the LINK.(http://support.asus.com/download/download.aspx?SLanguage=en-us).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 27, 2010 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Asus /eeetop ET2002. DVD is stuck inside and I cannot open CD/DVD drawer on theside.
make sure that the dvd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd rw then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
hope this helps
Dec 06, 2010 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
My computer doesn't register the ne.ASUS DRW 24B1ST - Disk drive - DVD±RW (±R DL) / DVD-RAM - 24x24x12x - Serial ATA - internal - 5.25" - black I had a ATA before and have now got a sata. The...
goto device manager,,...Open the "Run" dialog box by pressing and holding the Windows key, then press the R key ("Run"). Type devmgmt.msc.when it opens,right click the topmost icon,,choose "scan for hardware changes"..
sometimes,windows not show your dvd drive,unless you put a disk in.
Sep 15, 2017 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
ASUS DVD RW model DRW-1814BL
try reinstalling your operating system ( try format your cd or just repair it). The system will automatically detect the driver for your drive but if it was not listed in the bios try checking the cables attached to your drive.. or still if not.. the drive may be damaged.
Jan 22, 2008 | ASUS (90-N801W1000) DVD-RAM/DVD-RW Burner
ASUS DRW 24B1ST  Disk drive  DVD RW ( R DL)  DVDRAM  24x24x12x  Serial ATA  internal  525"  Burner Logo
772 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
