Question about Samsung LNT5265FX 52 in. LCD Television
Tv recently started taking a long time to start up , and when the picture shows up it has some runs in it like someone spilled something on it. I turn tv off and back on and no more lines. 52" lcd samsung like 4 years old
  • jowrench55 Sep 17, 2010
    The problem wound up being capaciators. Nine were replaced per samsung. They fixed my tv under warranty.
  • 732 Answers
If unit not covered by warranty, you or qualified lcd technician will need to investigate unit's "switch-mode-power-supply" for common (all brands) defects that can be the cause of this type symptom. HAVE YOU BEEN TO YOUTUBE YET???? Go there first!!! Then come back to FIXYA and tell us what you will do. Do your research first, then and only then do a comment and rate this response on fixya. When "very strange" things start to occur with any type (plasma or CCFL) lcd display, the first place I would investigate is the power supply board!! 12fixlouie
Posted on Sep 09, 2010
  • 20 more comments
  • Louis Ebert Sep 10, 2010
    jowrench55, Yes! If the units power supply board is functioning within specified limits you should also check the T-con board ribbon cable and wire cable high density connectors and then move on into the board surface-mounted integrated circuit components. May need to use low power inspection microscope (5x to 20x) to verify all component leads have solid (gas-tight) connections to the copper foil traces on the printed circuit board. If doing a DIY repair, you should always document your work with digital camera close ups before removing connectors or boards from the main chassis. Good luck on the hunt. 12fixlouie
  • Samsung Master
  • 8,457 Answers
This problems is the T-CON board about to dies.It the board,that sit right in the middle bottom of LCD screen.
    This was my original post for answer. Someone on here suggested you tube, and possibly warranty . They had a fix for my exact tv on you tube. Mine was out of warranty, of course, so I thought. I pushed the issue with samsung and got mine fixed for free. It wound up be the "capacitors" per phone call with samsung . They suggested to replace nine of them. They also sent info to repair shop, who in turn called me to set up appointment. Fixed for free ,and a great repair shop also. Thanks so much for suggestions for this post.
My brand new Asus Laptop's Touch screen just stoped working.
If you recently dropped your laptop or even spilled something on it accidentally, it would prevent your touch screen from working.
Sometimes the video card in laptops burns out depending upon how much and how long you keep your computer running and how many different software and programs you run at the same time.
If you're not familiar with your laptop I would recommend you ask someone who's familiar with computers, to take your video card out and check it into an compatible laptop and see if that's your problem. If it is, you would just have to replace it in order to work.
Sometimes, there are two possibilities that occur at the same time, and I recently discussed the first one above, and the other is that both your screen and video card managed to shortage almost at the same time.
I hope this helps you.
Aug 30, 2013 | Computers & Internet
I have a Philips projection TV model # 60PP920217F. The TV comes on but there is no picture. I recently changed the coolant in it and spilled a little on the circuit board. ( It was unplugged at the time.)...
The crt fluid needs to be repalced carefully and correctly...This is why we created step byt step instructions for our kits on our website www.TvRepairKits.com . In msot cases if you cleaned up the spill before powering up the tv would be fine....but its not always easy to get all the spill off the board.....look around and see if you find any burnt parts....if so post a photo here....
Feb 07, 2013 | Philips 60PP9202 60" Rear Projection...
Slow starting tv
This is common for LCD and plasma big screen tv sets.
If it takes over 2 minutes for the picture to show up, there might be something wrong, at which point you should call/talk to someone from where you purchased it, or contact the manufacturer.
Mar 07, 2011 | Televison & Video
I have a Sharp 36F-630 36" TV. Recently, it started getting a "band" across the top of the screen. It gets smaller as the tv warms up. It used to go away completely. Now it goes from...
You have a swollen capacitors in the vertical section try to replace all the leaky capacitors, you will notice that there is a liquid leaking out in the buttom of the capacitor.It is like an oil spill.
Dec 06, 2010 | Sharp 36F-630 36" TV
Some of te buttons on my keyboard are not working. It started wit it not working occaisnly but now does not work at all.
Did you recently spill something (coffee with sugar, soda-pop) into the computer?
As it dries out, the sugar starts to conduct electricity.
It's time to take your computer to a qualified technician, to replace the keyboard, because there is no way to "clean" the keyboard.
May 30, 2010 | Dell Studio XPS 16 Notebook
Volvo s40 t4 does not start
No that is just your rev counter sensor and want make any difference to the running of the car.Check to see if you are gettingspark to the plugs.Allso check your getting fuel from the pump.
Dec 28, 2009 | 2000 Volvo S40
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Dark fuzzy picture when tv is first turned on
I am having a similar issue. Did you ever figure out the problem??
Feb 29, 2008 | Televison & Video
Flickering
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tv1.gif or looking to buy one for parts.
call Richard At916-308-9272
raystockett@inbox.com
Nov 01, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Sony Trinitron shows distorted hexagon off color pattern in picture
Yes sure your tv can be fixed just call a tech and outline the problem.your tv has losted for a long time after repair it could last you a very long time congrats for keeping a tv for such a long time.
Apr 03, 2007 | Sony KV-27S42 27" TV
Samsung LNT5265FX 52 in. LCD Television Logo
294 people viewed this question
Jerry Greenberg
Jerry Greenberg
