Question about GE GSS20IEP Side by Side Refrigerator
Freezer computer board is bad need replace - GE GSS20IEP Side by Side Refrigerator
  • 101 Answers
Not hard pull plug small panel in back,go plug by plug
Posted on Sep 10, 2010
Side by side ge refrigerator doors feel hot, Items on freezer door not frozen.
send the model number,is other food in freezer still hard and cold?check ice cream best thing to check in freezer,if soft you know you have a problem,open the freezer door do you hear fan blowing?if not you could have a bad evap. fan motor or a bad computer board but you need to send model number and more info.
Jan 07, 2018 | GE Refrigerators
My refrigerator is working , but not the freezer
It could be the control board. I am curious about the fresh food working but not the freezer. the cold air comes from the freezer. Is the fan running in the freezer. It is possible the freezer fan could be bad. I have replaced them in the past. If you can return the control board if it doesn't fix the problem then change it. If not it is a gamble on replacing the board.
Nov 15, 2014 | GE G.e Refrigerator Wr55x10942 Motherboard...
Why does my refrigerator leak water on the floor and then the freezer will not freeze again until i unplug the refrig for about 20mins.
Your Freezer is frosted up you will need to remove all items from the fridge and freezer then you will to need to unplug the unit and remove the panel from the rear of the freezer compartment. You will likely see frost on the back wall even before you remove the panel. Once the panel is removed you will need to use a hairdryer to defrost the coils on the back wall. Place plenty of rags or towels in the bottom of the freezer to absorb the water from the melting frost You will need to know how to use a multimeter to do the next steps. Find the heater or heaters on the back wall of the freezer and check for open circuit using your ohmmeter. Sometimes you will be able to see the heater that is burned out . On GE models the heater will be mounted on a bracket or brackets on the rear wall of the freezer if two heaters are used replace them both if one is bad Also check the defrost thermostat for continuity and replace if open but be aware that the thermostat has to be cold to have continuity since it turns off the heaters when the temperature gets warm enough in the freezer.Most of the times the heater burns out causing your problem.Replace defective parts and reassemble.This should cure your problem.
Aug 04, 2014 | GE GSL25JFPBS Side by Side Refrigerator
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is not making ice. The water in the tray
Since cold air sinks, the fact you have frozen vegetables kind of points to the lack of circulation of the cooled air.
Sounds like they replaced two things which didn't need replacing and failed to check to see if the concealed fan that is supposed to distribute the cooled air was running. I don't think it is.
Oct 25, 2009 | Hotpoint HSS25GFP Side by Side...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
My freezer door seal doesn't "suction" anymore. i have ice build up.
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | Refrigerators
Whirlpool Refrigerator not cooling properly
I would try replacing the defrost timer and cleaning the condenser fins.
Apr 19, 2017 | Whirlpool ET1FHTXM Top Freezer...
Upright freezer
Three things could be the problem. Most likely would be the defrost thermostat which clips onto the evaporator behind the panel in the freezer. 2nd would be the timer or control board (will have one or the other). 3rd would be a bad defrost heater. Alot of times the def. therm. will show obvious sign of being bad by the cap on top popped open. You can check resistance on the heater. Any resistance at all on the heater means it is good. If it has a standard timer turn it clockwise until it clicks. This is putting it into defrost. If the heater comes on the timer is bad. If it has a control board you would unplug the unit then unplug the power supply to the board and jump line 1 to the wire going to the heater. While unplugged from the board and jumped, plug the freezer back in. If the heater comes on then the board is bad. If you are not sure how to test replace the def. thermostat, which is the cheapest part and see what happens. Note: When conducting the test for the timer or board the def. therm. must be freezing so don't defrost first! Hope this helps.
Oct 06, 2007 | Freezers
GE GSS20IEP Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
